Plz suggest budget AIO for Ryzen 5700x3d.
Budget 7k max
Im no expert in this, but try to stick to Corsair / Coolermaster 360mm ones, cuz this chip gets hot hot.
Are you looking for aesthetics, because spending 7k on an AIO for a 5700x3d makes little sense otherwise.
Maek sure it fits in your case, Rad is thiccckk
Buy Deepcool AG620, if you want something to keep CPU cool for cheap. For aesthetics as well, look at CM, MSI or Deepcool, they have AIOs under 7k. If possible look for Arctic options, considered great.
FYI, my friend is using AK400 for 5800X3D & I’m myself using AK400 for 9800X3D (although with UV). Unless you buy an Intel CPU that can consume 250W, you don’t need an AIO for cooling, air coolers are enough.
Can we stop promoting 2-3k rs coolers for a 45k cpu please, i know we can get away with those.. but every often or so you are met with a scenario like shader building or something where its better to have a better cooler.
AG620 should be the bare minimum if you have budget constraints.. otherwise I think it’s wise to invest in something better.. most AIO’s now have a 5-6 year warranty. They’ve become fairly cheap and premium brands like Noctua have lifetime bracket support.
I think it makes sense to spend 1 times on a good cooler.. a 45k cpu should be matched with atleast a NHD15 level cooler imo.
Just proving a point that you don’t need an AIO for most CPUs. AG620 is the minimum I recommend for anything more than R5 7600 & that is more than enough for 5700X3D for sure. Most 240mm AIOs don’t necessarily provide better cooling than AG620. Aesthetics is a different reason to spend money.
I planned to upgrade cooler when I upgraded CPU but out of curiosity decided to test it first. 9800X3D at stock at 100% load consumes 150W, temps were above 90C for sure but there was no throttling even for extended usage. After UV, temps are under 85C at 130W at 100% load. For gaming, temps are like 65-75C depending on the game. So I am not upgrading the cooler as of now as it is working pretty well.
How about Deepcool LE360 v2?
Specs_
Ryzen 5700x3d(wanna buy)
MSI b450m mro-m2 max(owned)
Team group 16GB(8*2)3600mhz ram
SEASONIC 620 psu(owned)
Ant eSports Crystal argb cabinet(wanna buy)
RTX 3060 ti gpu
Plz suggest any gud changes. I have 30k budget for cpu cabinet n cooler
I"m always against AIOs. They can conk anytime without a warning and then those leaks. AIOS can die a sudden immature death.
Invest in a good Air cooler. We have many members here who have gone through the horror stories owning an AIO and the next day they fired their rigs and radiator refused to work and then those leaks etc.
I afraid that this chip run on high temps. I’m looking for air cooler but results r not gud.
you can get Deepcool cg530-4F.
Avoid Ant esports
A noctua cooler with thermal grizzly kryonaut and you should be set.
Cooling doesn’t only depend on any aio or cooler but which cabinet you using and how are the fans placed and what all components are in there and if they could breathe easily or not.
Lots of factors come in play.
such a dumb comment , Noctua cost same as aio, Air cooler dump heat inside case increasing temp, its Indian subcontinent Everyone cannot afford ac or run ac and have 21c ambient Temp-usually 30-40 in summer, Aio helps a lot.
Should I go for 13400f but have to buy new mobo
You can also use it for 20 years without it dying or leaking.. has the quietest operations of all air coolers and most AIO’s and has lifetime platform support.
you can literally email noctua after 10 years and they will send you the brackets to use it on a newer platform post 10 years for free.
AG620 is great and functional. I use it with 7800x3d.
Just because a cpu costs x does not mean cooler has to cost y. That makes little sense other than to show off.
I have multithreaded workloads for work that use cpu to max. Have no issue with cooler. These x3d chips hardly have much heat to exhaust anyway.
To me liquid coolers have unacceptable risk of spilling out. And they are said to be more like consumables with limited lifespan.
I dont want the hassle, air cooler is one and done and decent pastes seem to last for years without trouble.
yes, @@Usman Raza is selling h610 for 4.5k you should get that, get air cooler arctic 36 more than enough will last you for life.
Yes i know that, they are chads..
Used my NH D15 for 9 years (2015-2024), before switching to the Freezer III. Had emailed Noctua with a copy of my invoice, and they sent me a free AM4 bracket kit when I switched over.
get 14400 non f
Deep cool cg530-4f
H610 from usman
arctic 36
this should be under 30k
Ok MR expert enjoy your AIO suggestions. Only if you had read my entire comment on overall cooling parameters.
Unfortunately, when your AIO leaks one fine day do ask Noctua to compensate for your pc bathing in some wet dreams! Nor Noctua comes with a written guarantee that its radiator wont fail or there wont be any leaks.
ANd btw only kids resort to ACs while legends know well how to keep a pc running cooler even in 45+c without ACs.
