When I look at the 12v case fans in the market I see some have shorter blades and a large centre core where the wire is wound and some other fans are opposite - meaning that the blades are large and the centre core is small.
My question does it make a difference which way the fan is built regarding…
Hmmm, from what i have seen with fans, often, fans with large sweeping blades offer good airflow. Just make sure the blades are of good quality, and are inclined at a large angle
Just to give a better idea of what I was trying to get across here is a picture of 2 fans - the left one is a Panaflo and the right one is a Mitsibushi.
well the fans you see with larger armature and small fins are usually high RPM and high CFM fans.
They are loud.
On the opposite side, the BIg blade fans are High CFM, low RPM and silent fans. They may not always give as much CFM as the tornado fans but they are preety silent.
Delta, Panaflo, Sunon = the best fans you can get. Those are industry grade fans. Everything else comes after that. Antec fans are not really worth the money.
I got 2x Delta 120MM 3 pin fans for 200 bucks each. They do about 3200 rpm and are very silent.
Look around some decent shops you will surely find it.
I have one of them colling my winne will try and post pics
What tha? They cost that much. Yup they are original all right. They work great too. I will surely pick up a couple more. I have a feeling that local shops dont really know the prices.
EDIT
ok so you have bought soemthing from there. Was there any problem when it came?
@ Rave
These are 3 pin fans so they connect to the mobo directly. Mobo give the rmp read out.
no didnt have to pay anything at the customs office. had to go there only to submit a write up,photostat of bill etc. later when the postman brought the stuff home they charged tax as well .. i got a lot of things with my xp 120 so tax was close to 1k
earlier i got the xp 90 for a friend (this is now with chaos) and they charged rs 200 tax. didnt have to go to customs office to provide any documents for this though. maybe coz it was a single item.
