Case with built in LCD panel
Can anyone help me with pc cases available in india that have built in LCD panels? I am not looking at DIY options since I want the screen to be part of the case. All form factors are fine, preferably under 15k and in white. Some models that I know of are the Lancool 207 lcd and some Ant esports models. I dont quite like their designs and want more options. I am also considering the Masterframe 360 lcd stage but its massive and a bit steep at 25k.
Looks dope. Available in India? I couldn’t find any listing.
Hyte Y70 Touch.
Also, an option (a bit of DIY) is get the O11 Mini (OG) and install a 14 inch portable monitor inside.
https://www.reddit.com/r/lianli/s/ANO2XIKku4
The Hyte is quite pricey. More than 45k.
Do we have any Indian site that sells such monitors at decent prices?
Amazon. Search for 14 inch portable monitor
Deepcool has some 3-4 models under 15k
Are you referring to the digital models? As far as I know, the screens aren’t customizable.
Most are over 10k and that too 15.6 16inch variants. Only Zebronics and Frontech options under 10k.
Yes, small screens are expensive!
Hence I did this:
This is nice. Too bad i disposed off my ancient laptops.
if you have space, run a 2 monitor setup. Buy a cheaper 24 inch or less pivot monitor.
Space constrained right now. Using a 27 inch monitor now. Am planning for a bigger oled later on but that will be a while.
