Corsair H115i RGB Pro XT & H80i V2 AIO's, NZXT Hue+, Kraken G12 GPU bracket, Nzxt Internal USB HUB (x2)
| [HEADING=2][Corsair ICUE H115i RGB Pro XT](’
https://mdcomputers.in/corsair-icue-h115i-rgb-pro-xt-cw-9060044-ww.html
)[/HEADING] Jan 2018 Sealed RMA unit
Warranty as per serial number
SOLD
[HEADING=2][Hydro Series H80i v2](’
https://tech4gamer.com/products/corsair-hydro-series-h80i-v2-high-performance-liquid-cpu-cooler
)[/HEADING] | Jan 2018 | Sealed RMA unit | ~~
Warranty as per serial number | 4000 | Used this on my 1080ti, before I replaced it a Kraken X53. Did a brilliant job cooling the 250W tdp card, as it has a thicker rad than most 120mm AIO’s in the market. ICUE compatible. |
| [**NZXT HUE+ RGB CONTROLLER AND STRIPS **](’
https://www.krgkart.com/product/nzxt-hue-plus-smart-rgb-led-controller-with-rgb-led-stripac-hueps-m1/
) | June 2019 | Used, functional | ~~
NA | 1800 | 1 Strip has some physical damage, but doesn’t affect functionality in any way. |
| [NZXT Kraken G12 GPU bracket](’
https://www.primeabgb.com/online-price-reviews-india/nzxt-kraken-g12-gpu-mounting-kit-kraken-x-series-aio-rl-krg12-w1/
) | May 2019 | Used, functional | NA | 1200 | ~~
Bundled a separate GPU fan header splitter |
| NZXT INTERNAL USB 2.0 HUB (2 UNITS) | Sometime in 2019 | Used, functional | NA | 1100 Each | |
Don’t need them anymore
  • Cash
  • Bank Transfer
@@Sanil Please send me DM. I can’t send you message because I am recruit. I am interested to buy Corsair H115i RGB Pro XT.
I would like to buy the RGB controller. I am a newbie with respect to fan controllers. Will this take control additional fans too?
Unfortunately this controls NZXT’s ARGB strips and fans only (someone correct me if I’m wrong). It’s from a time when there weren’t many motherboards with ARGB headers.
Yes I have Deepcool RGB fans. I am hoping to connect this to it. I wonder if its possible.
@@Sanil I think the controller is reserved for me and also in queue for Corsair H115i RGB Pro XT..
sAs it stands at the moment, yes. /s
Update: As of 11:58 AM H115i sold to @@idestinytechlab.
Dropped the package at the couriers, and shared tracking details.
@@Sanil Payment sent for H115i. Tracking details awaited.
Tracking details received. Waiting for package. Thank you.
bump
Which 1080ti do you have? Willing to sell it?
It’s stopped working in May. Not sure what’s up, but nothing happens; No fans spinning, not detected in Windows, doesn’t even heat up. :frowning:
Which brand is it? FE or otherwise?
It’s a Zotac blower based off the reference PCB design.
Also Bump
@@Sanil Cooler received safely and sealed. Thank you for the quick deal. Excellent packaging.
Bump.
Does the internal USB hub allow more USB 2.0 ports to come out of one USB2 9-pin header?
In other words, does it do the same things as this: Amazon.in
It appears to be same thing, but powered and can plug USB A dongles too.
Bump. Willing to let go of the H80i for 3.8k.
bump
bump
bump
