Have a look at this great tool.
You can create your very own TTF font with this. It is very easy to use. Once done you can save your work as .ttf files.
You can map each ASCII character with your own replacement character made into a 10X10 block.
There are lot’s of other option’s which make your work even easier.
I am trying to make a font and will post it here as soon as i finish it.
