[HEADING=2]Digitek® (DWM 101 Wireless Microphone System with ANC Noise Reduction, 360° Sound Capture, 100M Range, Upto 12 Hrs Working Time, for DSLR Camera, Android & iOS Smartphones, Seamless Audio Recording[/HEADING]
DigiTek (DWM-004) 2 nos of Noise Cancelling Wireless Microphone & one Receiver with 8-pin Connector, Fast Charging, Suitable for YouTube Vlog, Live Streaming, Video Shooting & More. Comes with 2 Wireless Microphone & one Receiver with 8-pin connector Receiver Indicator :Insert the receiver to mobile phone, the red and blue lights will flash alternately, indicating receiver and transmitter are pairing. The red light is always on indicating the transmitter and receiver are paired and working. Button Long press to turn On/Off the microphone (red and blue Short press to mute/unmute the microphone. Red and blue lights flash alternately, the red light is always on after paired flash alternately when mute. Built-in-50mAh Li-poly battery for to 4 Hours operation. Charging via USB(AC adapter or Power Bank-not included) Enhanced headphone monitoring function, allowing you to monitor in real tim e while shooting . with 3.5mm interface. with two 3.mm cables, can be used with laptop/PC/DSLR Camera / amplifier/ DV / Camcorder/ smartphone / mixer, etc. 360 degrees Ultra-Clear pickup/receiver equal amount of sound from all directions. Crystal-clear audio for any type of content creation. Plug and play-automatic pairing. the signal transmission with low latency & without interruption. suitable for video shooting. High performance wireless transmission-effective up to 30 meters. Ultra stable signal; audio & video synchronization
Specifications
In The Box
[td width=“187.012px”]Sales Package[/td]
General
[td width=“187.012px”]Brand[/td] [td width=“187.012px”]Model Number[/td] [td width=“187.012px”]Compatible With[/td] [td width=“187.012px”]Maximum SPL[/td] [td width=“187.012px”]Frequency Response[/td] [td width=“187.012px”]Battery Type[/td] [td width=“187.012px”]Battery Life[/td] [td width=“187.012px”]Sensitivity[/td]
