Cardinal principle of handling an electrical circuit board is to ground urself.On a pc this can be done very easily by merely touching the case(assuming ur pc is properly grounded of course.)
Sorry for not noticing this earlier. Hynix D43 chips will have codes similar to: HY5DU56822AT-D43 . Just look for the D43 extension at the end on the chips.
***Crazy_Eddy posted 6.72 minutes later:
***[quote]
[/quote]
Yep, the body of your PSU is connected to the ground terminal of your 3-pin power plug, and the PSU’s body in turn is in contact with the cabinet making your cabinet in contact with the ground terminal as well.
Your PSU should be plugged in to your AC outlet for your case to be grounded. Make sure you switch off your AC mains though to be careful, even with the AC mains switched off your ground terminal is still connected.
