Far Cry Problems
i get the bsod while installin far cry. can you help.
PC config?.. Is it a legit copy?.. And whats your optical drive?..
p4 2.4ghz, 512mb ram, gf 4440mx 128mb, 865gbf
its a 3 cd pack and i dont think its legit.
i have a combo drive from lg
OS ?
Where do you get the BSOD, do they occur while installing other games, btw that game will just about crawl on your system not worth it IMO.
The 3cd pack is a (Myth :wink: ) release.Its highly compressed and doesnt work well.
I could go on but lets just say anymore and this post would be removed for piracy concerns.
The 5 CD pack is the real deal.
the game works pretty good actually aces. heh on a gf4mx
okay!
ill clear all your wrong thoughts.
i installed it on my computer. i found the problem and fixed it. it was just because my NTFS partition had developed bad sectors and i installed it on my FAt32 partition.
secondly, the games running like butter on my computer and its fun to play. i dont feel it lag even a bit. and i have ended games like doom 3 on this machine and happy to do it. so dont be a high end machine showoff, if you like to play play anywhere you want.
