Fixing Double boot for Abit Motherboard
I am about to setup a new PC and I have selected the IP35-e, so I just wish to know whether it is still a good choice and whether the default bios would support the e7200 out of the box.
Sir- he said G92. You have a GTS640 iirc- G80. :slight_smile:
This is getting too freaky now. :face_with_tongue:
Ooooops :ashamed:
I was planning to get this board as a replacement for my faulty xfx 650i ultra. Will this board turn out to be a bad choice?
I don’t think, it’s bad choice.. Its kicka$$ overclocking board…
+1 for that
So does the Abit IP35 P have the same dual boot problem as the IP35 E? And is the P version better than the E version for my Q6600 and 2GB of 667Mhz RAM?
I guess double boot is based on luck my friend has an abit but he doesn’t experience double boot.
Anyways IP35-E is leagues ahead of IP35-P if possible try getting your self a P45.
Thanks for the quicky…so you mean the IP35 E is superior to the IP35 P? Then why is it priced over the IP35 E?
no luck…depends upon the bios version
