A10 5800k + A85F2-A Golden/Deluxe (<17k) combination looks very good and in this case I don’t have to invest in external GPU.With saved money I can add more 8GB RAM.
But how about the ECS service and support, I don’t think it will be available in local market. Even if I purchase online, how about the after sales support.
@axis.meister: I am running a 4000+ Athlon (A8 core) as a 24x7 server with a M3A78-EM and 4GB RAM, and 14TB of disks. Can’t really tell you about performance. The second rig is a PhenomII x4 970BE overclocked to 4GHz on water with two 6970s in crossfire and 8GB of DDR31866. I get 60fps sync locked performance on a 2560x1600 display and the rig is really quick. However it draws over 600W while running so it’s only used for gaming.
I don’t know that either combination is relevant to most people. I did run a AthlonII x4 620 for a very long time as my main rig on a 880G motherboard and was very happy with it. It was super-quick, ran very quietly and drove the large panel effortlessly (that’s not something all motherboards can do, ensure you have Displayport or dual-link DVI if you ever plan to look beyond 1920x1080.
The 5800K does have Virtualisation support.
@sky: The point was not about ECS (or indeed, buying from Lynx). There are some Asus and Gigabyte boards available with the A85 chipset. Your local market would have them if you are more comfortable with that.
@sky , yes, it does ask for a product key, but it’s free to get that. You have to register with them, and they provide you with the free product code. It’s similar to Avast Antivirus free. They do require registration, but it’s free. So, it’s not a problem :).
Paragon Backup and Free does have the option of partition backup and restore too. That’s how it will be able to image the main system partition, leaving the other partitions out :).
Try it, it’s a good product.
Otherwise, you can try Macrium Reflect free too. But, I haven’t used it, so I cannot say much about it, other then recommending it.
Sorry for replying late, I did not get the email notification for the replies on this thread.
I have assembled two systems yesterday (for my friends) with similar requirements. I bought the following components from Pune:
A10 5800k = 8500
Asus F2A85-M = 7250
Corsair Vengeance 1x8GB = 4900 ( I ordered for 2x4GB but it was not available, anyway planning to add 1x8GB after few months)
Seagate 1TB =4200
Cabinet Circle (don’t remember the model, 2 fans included) = 1100
PSU VIP500 = 2000
Monitor Dell IN2030M = 6200
APC UPS = 2300
Logitech combo = 800
LG DVD Writer = 925
Total = 36175
(They were on tight budget and going with PSU which comes with cabinet. Atleast I convinced them to buy VIP if not Seasonic).
Further plans are to upgrade cabinet and add Cabinet fans.
Thank you people who have provided their valuable inputs in deciding the RIG.
