G.SKILL Trident Z Neo 32GB (2 * 16GB) DDR4 3600MHz @25479
Product Name: G.SKILL Trident Z Neo 32GB (2 * 16GB) DDR4 3600MHz
Price:
₹25479
Link (in new line below):
Not a steal deal. Only 1 stock left.
Edit- warranty shows only 3yr but official clicktech seller, buy at your own risk.
I don’t know if I am allowed to share my ad here in this section but I have much better deal at - link
i have 8x4 same model lol thats a great deal as i saw somewhere with 40k price tag
That’s the DDR5 Variant
Appears to be ddr4
Can you share a reliable link? I find it hard to believe. Unless it’s a delusional Amazon/FK seller.
A 32 GB DDR5 CL 6000 MT/s CL30 kit is 40K
Silly for 32 GB DDR4 3600 Mhz to cost the same.
https://mdcomputers.in/product/g-skill-ram-trident-z5-neo-32gb-ddr5-f5-6000j3038f16gx2-tz5nr
Amazon.in: Buy G.Skill Trident Z RGB 16GB (2 * 8GB) DDR4 3200 MHz CL16-18-18-38 1.35V Desktop Memory RAM - F4-3200C16D-16GTZR Online at Low Prices in India | G.SKILL Reviews & Ratings go to see all buying options ,maybe this one now is 32k but still very high
Ah, it’s not worth it.
On MD, you can get Kingston Fury 2x16 3600 MHz CL 18 for around 24.5K
i already have 8x4 gskill , dont think i can afford anything rn.
If you are looking to buy DDR 4 then second hand market is the best.
Did you try ddr4 vs ddr5 whats the major difference in performance at all. i found that its a major difference only for ryzen builds
Absolutely, one can easily get 32gb with warranty for 12-14k.
