Gelid Thermal Pads
If you had checked the video you’d know he shows and explains the exact same micron specs you’re referring to and he’s not wrong because with my 3070ti it throttles when mem temps reach 96c. While it’s on the extreme case i.e with furmark and gaming pushes only till 90c max but in summers if does get to 96c then there’ll be throttling.
Try mining on it when you’re not gaming. Temps will hit 110 and thermal throttle near instantly even with an undervolt and maxed out fans. Nvidia uses terrible thermal pads on the fe cards
That’s bad I hope it’s not the case with 3070ti too, I think they improved a little with the ti series. I’ve mailed them, let’s see.
Tough luck. They still use the same 1.5w/mk pads
Where did you find that info? Can you link me to the source? As per my information Nvidia did not release any specifications of the stock white putty based thermal pads being used in their FE cards.
Can you atleast tell us where to buy it from? I searched on Amazon but your store isn’t selling it yet. Thanks.
Mail me at ray@scorpzontrading.com or pm me with your requirement address and number
I have PMed you with all the details. Thank you.
What do I do for Asus 3090 OEM? I mean which pads do I need?
Im not sure tbh, will have to look into it
thats lovely news to hear ,i hope you expand to some niche products such as Fujipoly ,graphene pads etc ,best of luck i hope people buy these and give you some more confidence so you could get some good top end stuff
I would like to buy these.
TP-GP01-C Extreme Thermal Pad 1.5mm 80x40mm 12 Watt Single Pack & TP-GP01-D Extreme Thermal Pad 2mm 80x40mm 12 Watt Single Pack.
Link 1.5mm and 2.0mm are missing/not listed on Amazon.
Please PM me for order placement.
does this work with cpu as well ?
No, it’s not for direct heat dissipation from actively cooled components like CPU/GPU die.
It’s for things like VRM, Memory chips on GPU, chipsets on motherboard which don’t require active cooling.
Why are the prices listed here more than the amazon prices, I was hoping to get a discount since there is no middle man.
Will update prices by tomorrow. Previous prices were our first shipment and were more expensive as a result.
Thank you, much appreciated.
Hi Ray
You haven’t sent me thermal paste of which I paid you 2 months ago.Nor you are replying to my msg.i have sent 100 msgs to you and contact you gave.ordered for 2 pads and mx4 paste,received pads but you forgot to ship paste.and now you are not even replying msg.Mods kindly look into it
Thanks
Hey Ashok I was unaware of the same. Please drop me a message on WhatsApp and I’ll make sure you receive it.
