ok, so i install the final version of XP x64,…everything goes fine…(installed version includes service pack)
FYI my config - AMD64 3000+ ,asus K8N, 256 RAM.
Now…i install my latest nvidia nforce 64 bit 250 drivers, also nvidia 64 bit display drivers.and my Realtek AC97 64bit drivers.
Now everything works fine, networking n all…except…i get this error !!
I get a bubble saying i have a system error.. Event 106.
this is what it says.
so i go check on microsoft site and find out many people are facing the same problem…and apparently the solution is to re-flash your bios.
ok…now…1stly…my driver cd which i got alog with the motherboard does not recognize my motherboard …meaning it says its not asus.
now i have 2 files which i think are bios files…plz help me here…
one is K8N.rom (512kb) and the other is K8N1004.ami (downloaded from asus site recently)
now…1> my asus bios flasher is not 64bit compatible, hence it does not work, nor does the asus update utility.
2> if i have to,..how do i flash my bios ,and which file do i use. :huh:
thts all for now…need feedback asap !!
p.s - no AV works,…had read somewhere that NOD32 does,..tried it..but it does not ! suggest 64bit compatible AV also !!
What video card?if ur card has different 2d and 3d clocks-that error is actually an unsuccessful transition from one to the other,fairly common and nothing to worry about.
update..-- i reflashed my bios with the old k8n.rom which is included in my motherboard driver cd by the alt + F2 method.
but its still the same…
i need to update it with the new bios which i downloaded from the asus site, but its K8N1004.AMI …now how do i use a ami file type to upgrade ??
using the alt +F2 method..it says 'could not find ‘K8N.rom’
why dont you use the afudos utility that comes with the bios files at asus site ? create a bootable floppy and then copy the afudos and the bios file then boot from the floppy and use the afudos command to flash the bios. think the command is
afudos /i
but check out the exact command to use by typing afudos /? at the prompt
alternatively you can try renaming the .ami file to k8n.rom and dumping it on a floppy and then use the alt + f2 method
