which workstation laptop?
I donât believe you have the correct sense of downloading something over the internet and downloaded some crappy version of VMware from a malicious site. As the official site / VMware Trial would not install any unwanted stuff along with your trial.
Here is a video on installing the latest OSX Sierra on VMware Workstation.
To download VMware Workstation Pro Trial click on the link below.
https://www.vmware.com/in/products/workstation/workstation-evaluation.html
This is my own personal channel, its not polished yet but will get there. and you can also look at my other videos on Windows 10 and fixing any issues you might have, maybe list them to me via a pm? & iâll make a video out of it
And please just because you donât like an OS doesnât mean that you have to spend exaggerating amount of money on less hardware, as there are bound to be bugs in Mac OS as well. These OSâs are work in progress, whether its Mac, Windows or Linux.
I would advice against the latest gen MacBook âProâ merely because of the hardware specs for the price.
Current Gen macbook pros would be better. Retina screen and will be able to handle 4k monitors. New ones would cost a lot more
Post merged on Nov 18, 2016
Try to get it in one of these discounts or sale offers.
Any. The HP Pro series or the Dell precision series.
There are also couple of options from Sager/Clevo which you can look at, if interested in a VFM system.
Please look at some popular sites that public everything Apple / MAC. You can google search for it.
here is an example: a must read if you want to purchase the new MacBook Pro.
https://9to5mac.com/2016/11/15/2016-macbook-pro-non-removable-ssd-small-batteries/
Want a really portable and 15-inch laptop with good battery life. I really like the Dell XPS 15. Can get it from the US.
If I get it , can I install Mac OS Sierra on it alongside windows and use it as my main OS?
Will it cause any problems? Will it run as good as it runs on a macbook?
yes if you follow the guide mentioned here as though its from God
https://www.tonymacx86.com/threads/guide-dell-xps-15-9550-skylake-gtx960m-ssd-via-clover-uefi.192598/
Thanks for this. But itâs kinda impossible to download a 13GB+ file directly with my 2mbps connection. Keeps getting interrupted and failing.
Is there anyway I can download from a source from which I can resume when internet disconnects?
@@GODMODE09
Sorry was out of town this weekend, I will upload a split version. would 1GB per file be enough?
Post merged on Nov 29, 2016
found a smaller sized version if OSX vmdk file at https://goo.gl/DZTaKi
but this is untested by me so i cannot be sure if this will work or not.
The files are split into 5 parts of 1 GB each.
For what itâs worth - what I feel is the best part about OS X is negated by hackintosh - which is the ability to open your laptop after an hour (or 15 days for that matter) and continue working on where you left off within a second.
Itâs like if it were an Android or iOS phoneâŚ
Now please donât tell me that Windows laptops too have standby - Every single windows laptop which I am have used (and I have used way more than several) has been a hit & miss on standby (sometimes the network stack wonât start correctly or any of your pre-open apps will thrash the HDD for several seconds when you switch to then post standby)
Add the brilliant trackpad (which again is far superior to anything currently available on Windows) , the insane PCI SSD speeds and the overall quality of the hardware - Suddenly they donât look overpriced anymore
I used a core M3 macbook 12 at home and my work machine is an i7 XPS13 - Let me just say that if I am working from home, I inevitably work off the macbook and not the XPS13
However, Am pretty certain that I would have used windows on the XPS 13 instead of hackintosh on the XPS13
Hi.. thanks for this. But before I proceed , I want to completely uninstaled the VMware I tried to install before which was infected.
Right now , itâs causing some problem. Every 1 minute a cmd window flashes and closes on itâs own for a fraction of a second and panda antivirus is also showing âreboot requiredâ all the time evenn after I ran full scan , etc etc.
No able to see VMware in conrol panel programs or even in ccleaner. I need to clean my laptop first. How do I delete this partially installed infected VM ware?
Thanks in advance
Reboot your computer first, as windows might have locked VMware files & hence the issue you are facing.
Then use the link below, scroll down to manual cleaning steps & follow the guide.
https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1308
