I dont have any purple colour in any theme I use… what I use now is deep blue in colour … maybe your setup shows what is dark blue on my screen as a purple
You can Convert a fat32 partition to NTFS using convert command without formating, and definitely NTFS and FAT partitions coexists.But be sure to convert because its irreversible , converting ntfs to fat will require formatting.Also MS-DOS cannot read NTFS drives , so it will be better to keep C:\ partition as fat and covert other to NTFS.
Correct me if I am wrong - but I thought using the convert command of XP to change files system from FAT32 to NTFS has one hassle which is that this creates allocation units of 512bytes (0.5kb) whilst a normal format creates allocation units at 4096bytes (4kb). If this is correct then running a HDD with 512bytes allocation units size would be a bit slower.
