Pune. Not spending more than 10k on a switch.
How about this single switch to rule them all?
No need to get me 2 managed switches plus another poe switch for ip cameras (I’ll use cheap poe injectors for them).
I think it supports most of the managed functions needed.
Goes around for 8k.
Reliability . Plus a hell a lot of features . If you have some basic knowledge of vlan you can do it . Cisco documentation is also quite good with many forums .
Oops, didn’t notice the VLAN C. In any case, I think a smart switch is enough for your case. TP-Link TL-SG1016PE has both VLAN tagging and POE, and is 8k.
I think this can be done at the router - you don’t need to a separate VLAN for this. A VLAN for a single device is overkill. Combine B and C into one VLAN B. VLAN B doesn’t have access to internet by default, but the NVR and the IP Cam (within VLAN B) has access to internet. Also, your VLAN A can initiate access to VLAN B, but VLAN B cannot initiate access to VLAN A. In fact it may be be better to move the NVR to VLAN A.
I know this is possible on PfSense and Unifi, so should be possible on Omada firewall too. Here a good video on how to set it up for Unifi (doesn’t help you directly, but explains the concept)
Don’t think so, as VLANs are layer 2 while IP is layer 3. What type of attack vector are you considering? Maybe someone overwrote the firmware of your IP Cams to impersonate the MAC of your NVR?
Sorry for the late reply.
Think of spoofing the IP and mac address and making the router believe that the device belongs to some different vlan.
