How are you getting it for 33-34K? It shows to me as ā¹37,490.
By using credit card discount, it had much more discount bur for now lowest after using credit i can get is 35k
I got two panasonic 1.5 ton 3 star ac. I would say that its the best bang for buck out there.
When did you buy them, and how was your experience with them?
1sr one I got last year and its running well. Secong one i got this April and its the newer model and better. The newer model has a bigger indoor unit. The remote is a bit of a miss but overall its the best at its price range.
Link please.
For semi-urban areas, prioritize ACs with strong service networks - go for LG or Panasonic inverter models (3-star) in your budget. Avoid lesser-known brands even if specs look good - service delays ruin summers.
Hello,
to all of you.
I am planning to get an AC, I have chosen the below model, I am getting this for Rs.35500 using a Credit Card in offline mode plus 1200 + GST for Installation, Please share your views on this, Hope to see replies soon.
Thank You
Regards,
LAPTOP_GEEK
Looks like an okay deal but try to get a 5 star one as the higher efficiency will save you money in the long run. You will most likely recover the extra money spent in the first 2 years itself.
Look at this
Check out the Panasonic 1.5 Ton 3 Star Inverter AC ā decent performance, and usually falls under ā¹36K during sales.
Hello,
to all of you,
I am getting this for Rs.39200 using a Card Offer, Should I go for it? Please reply soon as Offer is time limited. Thank You.
LAPTOP_GEEK
Yeah go for it buddy, I remember buying a 1Ton 5 star one for the same price (although had no discounts like CC or anything)
I bought Daikin, Samsung, Panasonic and Voltas ACs over the last 3 years. Extremely happy with Panasonic cooling and service quality. I even purchased their AMC. Daikin people never bothered with calls for free service which we missed, then when we called to ask about service they were rude.
Would recommend you avoid Voltas and Samsung. Voltas made noises and required warranty repair and Samsung service is not upto the mark and remote developed issues.
How is sharp ac? Although Iām late for it as my dad already ordered it but it provided 7 years warranty, and its 5 star and Iām very happy with the cooling.
