Help needed in deciding IEM
Guys finally my budget increased. I decided to buy Klipsch s4I after research through different forums.
Are they available in TE? And compared to M2 how much VFM these with 1000/- extra?
I have read that M2 are S4-killers. Although I don’t know how accurate this statement is.
From what i have read , s4 and 2 are different , both excell at different areas.
S4: build , fit , bass, soundstage.
M2: balanced sound , mids, highs, good bass.
interested in re1 for 3.2k??
i think he wants an IEM with mic.
though one can buy cable that has mic too, but that will work with his W3 aslo.
Hello Strategy,
MIC is not at all an issue. My preferences are good bass, Sounstage(I realized this is what i want from faheems post) and comfort ,as i need to use mostly in gym and while sleeping.
Mukul give me some time and i will let you know as i have no idea about RE 1(need to research about it :face_with_tongue: ).
As of now M2, Klipsch S4i seems to by options. Lets see if i find any IEMs under 4000/-.
You could also consider Brainwavz M3, but it isnt available in India as of now.
If you need soundstage, then between S4 and M2 get S4
You can buy klipsch s4i from TE dealer prashants website:
Intencity - Klipsch Image S4i Headphones (black)
I m in no hurry
U r in only one in line for the time being as i hav not put on FS forum
its 3 months old and re1 needs an amp to really show its true colors
without an amp it is good except soundstage
