Help - Unable to use router to connect to net
well that helped, hooked up the cable to another ethernet port and I can browse net from the first comp now.
however the new problem is, I cant access my router page, using 192.168.1.1 in the browser address takes me to a 24online page, which I suspect is at the cablewalla’s end.. and also I cant use routerlogin.net as an alternative to use the router page, as it takes me to netgears website..
In the second comp, under network connections in control panel, I see that there is an active internet connection(shared), but I cant browse.. what seems to be the issue here?
Change your routers IP…
how do I do that?
hi,
Dear Mr chetan,our guys came several times your Residence but your not there your mom told that come after your comes,so better your call our guys between 10AM-6PM they will come configure your router.or else in your router select my net connection requires user name and psswrd then enter your user detials in that box and call our guys to reset the Mac address than it will login your router,there is no need to login in your machine,dont try to login in your machine.
regards
vijaykumar sajjan
for further help mail vijaysajjan@gmail.com
