So if I buy KIS 2015 (3 years), by the the time KIS 2018 releases, would I still be using KIS 2015 or am I entitled to free upgrade every year (sounds unlikely).
You should be able to upgrade, i have upgraded my KIS in the past with a key from the previous version.
Yes, You can upgrade your existing Kaspersky to future updates until your license get expired.
It will upgrade automatically when updates comes, until your license is active.
