How is Phillips One blade?
Looking to buy phillips one blade mainly for shaving, is it any good and provides clean shaven look?
I went to bombay razor shaving long time back with normal gilette razor blades.
Never looked back.
Just sharing it as an option …
Cheaper and does great job. Specially with my beard which grows every second day and are razor sharp like wolverine.
do u mean those single blade razors? I am still amateur at shaving ,have only used trimmers ,are they safe ?
The one I have is completely crap. It seems to be made for teens who have very little facial hair.
Oneblade is also the entry level shaver from Philips, they have a lot many which are a lot better.
It is little tricky at first.I won’t lie …I did hurt my self a lite few times when I first started.
But it is matter of few days and you should be fine with it too.
Nothing to be that scary just take it easy though and understand how it works.
It’s a sign, your body wants you to be more manly.
EDrop_1768740018088
Let it grow.
Ha. Dexter, Flintstone and Jetson all in one frame. Thanks for the nostalgia.
