This indicates that your modem does not have the ability to install and get detected as fake 3G device.. You might want to try them with any other PC’s. If it still does not work then probably you will need to get them check by product manufacturer!
The modem is not getting detected by the computer, I tried installing firmware but the software is unable to detect the modem. Even Mobile partner is unable to detect the modem.
What should I do, need a step by step guide…
Nothing much can be done in that case, take the modem to product manufacturer and they will check it.
