Yes. Seller mentioned itx and Google says it comes in different sizes. So, as someone out of the loop its not obvious to me what the appropriate/compatible case is just by looking at the pics or going by past threads. If there was a model number that would have helped.
Anyway, I don’t want to take this thread off-topic any further. If required, I will create a separate thread on that later if/when I get a board.
It is ITX = 170 mm × 170 mm
Majority of cabinates supports all 3 sizes, ATX, mATX and ITX (But always check before buying, if it says ITX, mobo will fit)
The board supports ATX PSU (24pin + 4 pin for cpu) power supply, even if you have 4 HDDs, 300W PSU should be enough
I have plugged in the ITX board in my 15 years old Intel ATX cabinate, and it fits nicely
If you have any cabinate in mind, feel free to DM, i will confirm.
Great, feel free to contact, if you have any questions or for any thing.
Those looking at the pic :
The item actually comes wrapped safely in multiple bubble wraps, a plastic bag specially made for wrapping sensitive electronics etc
At a glance, the BKHD 1264 NAS motherboard does not support Active State Power Management (ASPM). One user reported their unit consumed 21 watts at idle partly due to the lack of ASPM support.
