Every monitor or TV you buy uses one of four core technologies to create the image you see: IPS, VA, TN, or OLED. Understanding these isn’t just technical trivia—it’s the difference between buying a ₹25,000 monitor that fits your needs perfectly and one that frustrates you daily.
Over the past year, we’ve analyzed 23+ forum threads where TechEnclave members debated panel technologies, often with contradicting advice. “VA has better contrast!” argues one side. “VA ghosting ruins gaming!” counters the other. Both are right—because they’re talking about different quality tiers of VA panels without realizing it.
This guide explains how each technology actually works, what trade-offs matter in real use, and most importantly: why a ₹15,000 VA panel behaves completely differently from a ₹40,000 VA panel, even though both are “VA technology.”
What You’ll Learn:
- How IPS, VA, TN, and OLED create images at a fundamental level
- The real-world implications of each technology’s strengths and weaknesses
- Why panel quality varies dramatically within the same technology type
- India-specific considerations: heat tolerance, power consumption, warranty coverage
- Use-case recommendations: which technology for gaming, productivity, content creation
- The OLED burn-in and text clarity debate: separating fear from reality for desktop use
Quick Reference: Panel Technology Comparison
| Feature | IPS | IPS Black | VA | OLED | TN |
| Best For | Productivity, Color Work, Casual Gaming | Coding, Writing, Professional Work | Movies, Dark Room Gaming | Premium Gaming, HDR Content | Budget Esports Only |
| Contrast Ratio | 1000:1 | 2000:1 | 3000:1+ | Infinite | 1000:1 |
| Viewing Angles | Excellent | Excellent | Poor (Gamma Shift) | Excellent | Terrible |
| Response Time | 4-6ms (Fast) | 4-6ms (Fast) | 4-20ms (Varies) | <0.1ms (Instant) | 1-2ms (Fast) |
| Major Flaw | IPS Glow / Backlight Bleed | Higher Cost | Ghosting / Smearing | Burn-in + Text Fringing | Poor Colors |
| Text Clarity | Excellent | Excellent | Good | Good (Gen 3+) / Poor (Older) | Good |
| Price Range (India) | ₹12K-₹50K | ₹30K-₹80K | ₹10K-₹50K | ₹60K-₹1.5L+ | <₹10K |
Understanding the Core Technologies
How LCD Panels Work (IPS, VA, TN)
All LCD (Liquid Crystal Display) panels share the same basic structure: a backlight shines through liquid crystals that twist to control how much light passes through color filters. Think of it like venetian blinds—the crystals rotate to block or allow light through.
The difference between IPS, VA, and TN is how those liquid crystals are aligned when voltage is applied:
IPS (In-Plane Switching): Crystals rotate parallel to the panel surface. This alignment means light can pass through from wide viewing angles without color shifting. The trade-off? Light “leaks” around the edges even when trying to display pure black, reducing contrast.
IPS Black (Advanced IPS): A newer variant of IPS using refined crystal alignment and improved polarizers to achieve ~2000:1 contrast ratio instead of standard IPS’s 1000:1. Found in premium productivity monitors like Dell UltraSharp U2724DE and ASUS ProArt PA279CRV.
VA (Vertical Alignment): Crystals stand vertically when showing black and tilt when voltage is applied. This alignment blocks backlight extremely well when vertical, creating deep blacks and high contrast. But the tilting motion takes time, which can cause ghosting in fast motion.
TN (Twisted Nematic): The oldest technology. Crystals twist in a spiral pattern. Fast response times but terrible viewing angles—look from the side and colors completely shift. Largely obsolete now except in budget or esports displays.
How OLED Works (Fundamentally Different)
OLED (Organic Light-Emitting Diode) panels don’t use a backlight at all. Each pixel creates its own light. When displaying black, pixels turn completely off—no light, no power consumption, perfect blacks.
This sounds superior (and often is), but the organic materials degrade over time with use. Display the same bright element in the same spot for months, and that area wears faster than surrounding pixels—the infamous “burn-in” concern.
The Subpixel Layout Challenge: Unlike standard RGB panels, many OLEDs use non-standard subpixel arrangements (WBGR or triangular patterns) which cause text fringing on Windows—text edges appear colored or blurry. This is the #1 complaint from coders and writers on TechEnclave.
IPS Panels: The Color-Accurate Workhorse
What IPS Does Best
IPS panels dominate professional work and productivity for good reason. Forum members consistently report:
Accurate Colors: One graphic designer member shared: “Switched from VA to IPS for photo editing. Colors now match prints from the lab without endless color correction.” IPS typically covers 95-100% of sRGB color space even in budget models.
Consistent Viewing Angles: Look at an IPS screen from 45 degrees to the side, and colors barely shift. Multiple forum members mentioned this matters more than expected: “I do code reviews with colleagues looking at my screen. IPS made a huge difference—they could actually see the code without color inversion.”
No Ghosting: IPS response times aren’t as fast as TN, but they’re consistent. You won’t see trailing shadows behind moving objects the way budget VA panels show.
Perfect Text Rendering: Standard RGB subpixel layout means crisp, clear text with no fringing or color artifacts. Critical for anyone who reads/writes code or text for hours daily.
IPS Black Technology: The Bridge Between IPS and VA
Starting in 2023-2024, premium productivity monitors introduced IPS Black technology (also called “IPS Black Technology” or “Black IPS”), addressing IPS’s biggest weakness: poor contrast.
What IPS Black Delivers:
- 2000:1 contrast ratio (double standard IPS’s 1000:1)
- Deeper blacks without VA’s ghosting issues
- Maintains IPS viewing angles and color accuracy
- Eliminates most IPS glow (though not all backlight bleed)
Available Models in India:
- Dell UltraSharp U2724DE (27", 1440p, ₹42,000)
- Dell UltraSharp U3224KB (32", 4K, ₹85,000)
- ASUS ProArt PA279CRV (27", 4K, ₹48,000)
Forum Member Experience:
“Switched from standard IPS to Dell’s IPS Black monitor for coding. The difference in black depth is immediately visible—no more gray backgrounds in dark mode. Text clarity is still perfect, but now dark themes actually look dark.”
— Anonymous forum member
Who Should Consider IPS Black:
- Coders/writers who want deeper blacks without OLED burn-in risk
- Productivity-focused users in mixed lighting conditions
- Anyone who found standard IPS contrast insufficient but doesn’t want VA’s viewing angle issues
Where Standard IPS Falls Short
Contrast Limitations: Standard IPS typically delivers 1000:1 contrast ratio. In dark room viewing, forum members note: “Blacks look more like dark gray. Watching movies at night, I can see the backlight glow in letterbox bars.”
Backlight Bleed and IPS Glow: This is IPS’s most complained-about flaw in our forums. Light “leaks” from panel edges (backlight bleed) or appears as a whitish glow in corners when viewing dark content (IPS glow).
“Bought the LG 27GL850 after seeing rave reviews. Colors are fantastic, but the IPS glow in the bottom corners drives me crazy when gaming in dark scenes. Tried three units—all had it to varying degrees.”
India-Specific Note:
IPS panels handle heat reasonably well, but cheap IPS monitors from no-name brands often show increased backlight bleed in Indian summer temperatures (35°C+ ambient). Stick to established brands (LG, Dell, ASUS, BenQ) with better quality control. Internal power brick designs can fail faster in hot conditions—external adapters are easier to replace.
Power Consumption: IPS panels require constant backlight power even when displaying dark content. In India’s power scenario, this means slightly higher electricity bills and more heat generation compared to OLED.
Best Use Cases for IPS
Choose Standard IPS if you:
- Do color-critical work (photo/video editing, graphic design)
- Need wide viewing angles (multiple people viewing, or monitor not directly in front)
- Use monitor in well-lit rooms (IPS glow less visible in ambient light)
- Play fast-paced competitive games (no ghosting, good response times)
- Want consistent experience across budget to premium tiers
- Work with text extensively (crisp, clear rendering)
Choose IPS Black if you:
- Code or write 8+ hours daily and want deeper blacks
- Can afford premium pricing (₹40K-₹85K range)
- Want IPS benefits without standard IPS’s contrast compromise
- Work in mixed lighting (need good blacks without dark room-only OLED)
Avoid IPS if:
- You primarily game in dark rooms (contrast and glow issues become obvious)
- You’re extremely sensitive to backlight uniformity issues
- You watch lots of movies/cinematic games (VA’s better contrast or OLED’s perfect blacks enhance experience)
VA Panels: The Contrast King with a Ghosting Catch
What VA Does Best
Exceptional Contrast: VA panels deliver 3000:1 contrast ratio or higher—three times what standard IPS provides (1.5x better than IPS Black). Forum members consistently note: “Switched from IPS to VA (Samsung Odyssey G7). The difference in dark scenes is night and day. Blacks actually look black now.”
Deep Blacks Without OLED Burn-in: VA gives you significantly better blacks than any IPS variant without OLED’s burn-in concerns. For HDR content, this contrast advantage makes a massive difference.
Good Color Accuracy (in Modern Panels): Older VA panels had poor colors, but modern VA matches IPS for color gamut. Samsung’s Quantum Dot VA panels, in particular, cover DCI-P3 color space adequately.
The VA Ghosting Problem (and Why It Varies So Much)
Here’s where VA gets controversial. Forum discussions show extreme experiences:
Forum Member Experience A:
“Bought a ₹15,000 VA monitor (Samsung F24T35). Ghosting is horrible—can’t play fast games at all. Text scrolling leaves trails. Even at 75Hz, motion clarity is worse than my old 60Hz IPS.”
Forum Member Experience B:
“Samsung Odyssey G7 (VA panel, ₹45,000). Zero ghosting issues. Plays Valorant at 240Hz perfectly. Curved design actually helps with VA’s viewing angle weakness.”
Both are telling the truth. The quality spectrum within VA technology is enormous.
Budget VA Panels (₹10,000-₹22,000):
- Response times: 10-20ms gray-to-gray
- Visible ghosting in fast motion
- Noticeable black smearing in dark transitions
- Often use older VA panel technology
- Examples: Samsung F24T35, BenQ GW2480
Mid-Tier VA Panels (₹25,000-₹35,000):
- Response times: 6-8ms gray-to-gray
- Moderate ghosting (noticeable but not game-breaking)
- Better pixel response time consistency
- Examples: MSI MAG274QRF-QD, Gigabyte M27Q (VA variant)
Premium VA Panels (₹40,000+):
- Response times: 4-5ms gray-to-gray (with overdrive)
- Minimal ghosting even in fast games
- Samsung’s SVA (Super Vertical Alignment) nearly eliminates the issue
- Better pixel response time consistency across all transitions
- Examples: Samsung Odyssey G7/G8, ASUS TUF VG32VQR
One forum member did direct testing: “Compared my old ₹18K VA monitor to friend’s Samsung G7. Same panel technology on paper, completely different experience. The G7 had maybe 10% of the ghosting. Curved design also helps keep viewing angles consistent.”
Viewing Angles: VA’s Legitimate Weakness
Unlike ghosting (which varies by quality), VA’s narrow viewing angles are inherent to the technology. Look at a VA panel from 30-40 degrees off-center, and you’ll see:
- Colors shift toward gray/washed out
- Contrast degrades significantly (gamma shift)
- Text becomes harder to read
- Blacks appear lighter from angles
Forum consensus: “VA viewing angles are fine for single-person use directly in front of the monitor. If you share your screen or sit off-center, IPS or IPS Black is better. Curved VA monitors help by keeping edges pointed at you.”
Best Use Cases for VA
Choose VA if you:
- Game primarily in dark rooms (contrast advantage shines here)
- Play single-player cinematic games (HDR + contrast = immersive)
- Can afford premium VA (₹35,000+) if gaming competitively
- Sit directly in front of monitor (viewing angle limitations don’t affect you)
- Watch movies/shows frequently (deeper blacks than IPS enhance experience)
- Want better contrast than IPS without OLED’s burn-in risk
Avoid VA if:
- You’re buying budget tier (₹15K-₹20K) for fast gaming—ghosting will frustrate you
- Multiple people need to view screen simultaneously
- You do color-critical professional work (IPS still safer choice for consistency)
- You play fast-paced competitive shooters (even mid-tier VA ghosting affects aim tracking)
VA panels handle heat well, but some forum members reported contrast shift in extreme temperatures (40°C+ room temps without AC). Keep monitors in climate-controlled spaces for consistent performance. Several members noted curved VA monitors are harder to service in India—verify service center support for curved panel replacements before purchasing premium models.
TN Panels: The Fading Champion
TN panels dominated esports for years due to 1ms response times. But they’re rapidly disappearing from the market, and for good reason.
What TN Still Offers:
- Fastest response times (true 1ms gray-to-gray)
- Lowest input lag
- Cheapest to manufacture
- Good text clarity (standard RGB subpixel layout)
Why TN is Dying:
- Terrible viewing angles (colors invert when viewing off-center)
- Poor color accuracy (60-70% sRGB typical)
- Washed out, lifeless image quality
- Modern fast IPS and premium VA have closed the speed gap
Forum sentiment is clear. In 23 threads discussing panel types, TN was recommended exactly zero times. Multiple members shared: “Upgraded from TN to fast IPS (165Hz). Can’t believe I tolerated TN colors for so long. Gaming experience is so much better with proper colors. Response time difference is negligible.”
When to Consider TN: Only if you’re buying ultra-budget (under ₹10,000) and exclusively play competitive FPS where every millisecond matters more than image quality. Even then, fast IPS panels at ₹12,000-₹15,000 offer vastly better overall value.
OLED Panels: Perfect Blacks with Burn-In and Text Clarity Reality Checks
OLED has entered the monitor market in India with models like LG’s UltraGear OLED and ASUS ROG Swift OLED around ₹80,000-₹1,20,000. The image quality is transformative, but desktop use requires understanding two critical trade-offs: burn-in and text clarity.
What OLED Delivers
Infinite Contrast: Each pixel produces its own light. Black pixels turn completely off. The result? Perfect blacks with no backlight bleed, no IPS glow, no VA viewing angle issues.
Instant Response Times: No liquid crystals to rotate means zero ghosting, no motion blur, perfect pixel response time consistency for fast gaming.
True HDR: With per-pixel brightness control, OLED delivers HDR the way it’s meant to look—highlights that pop against perfect blacks without blooming.
Forum member reaction to first OLED experience: “Tried the LG 27GR95QE at a friend’s place. It’s not an incremental upgrade—it’s a different category of display. Gaming felt like putting on glasses for the first time. But when I opened VSCode to show him my project, text looked fuzzy compared to my IPS. That’s when I learned about the subpixel issue.”
The OLED Text Clarity Problem: Subpixel Layouts Explained
This is the #1 complaint from coders and writers on TechEnclave about OLED monitors.
Standard LCD panels (IPS, VA, TN) use RGB stripe subpixel layouts—neat rows of red, green, blue subpixels that Windows’ ClearType rendering expects. OLED panels, particularly earlier generations, use non-standard layouts:
Older OLED Layouts (2021-2023 models):
- WBGR (White-Blue-Green-Red): LG WOLED panels
- Triangular/Pentile: Samsung QD-OLED Gen 1-2
- Result: Text edges appear colored (red/blue fringing), slightly blurry, or “fuzzy” especially on white backgrounds
“Bought the ASUS ROG Swift OLED (PG42UQ, 2022 model) for both gaming and coding. Gaming is flawless, but after 2 hours of coding in VSCode with white background, I got eye strain. Text has visible color fringing. Ended up returning it and getting IPS Black for work, keeping budget IPS for gaming.”
Newer OLED Improvements (2024-2025+ models):
- Gen 3 QD-OLED: Samsung Display’s third-generation QD-OLED uses improved subpixel arrangement
- Newer WOLED: LG Display’s 2024+ WOLED panels have better subpixel structure
- Result: Significantly reduced fringing, though still not quite as crisp as RGB stripe IPS for text
Models with Improved Text Clarity:
- ASUS ROG Swift OLED PG27AQDM (2024, Gen 3 QD-OLED)
- MSI MPG 321URX (2024, Gen 3 QD-OLED)
- LG 27GS95QE (2024, newer WOLED)
Forum Consensus on Text:
“If you code/write 50%+ of the time, test OLED text clarity in-person before buying. Gen 3 QD-OLED is much better than Gen 1-2, but IPS/IPS Black still has the edge for pure text work. For gaming-primary use (70%+ gaming, 30% productivity), newer OLEDs are fine.”
The Burn-In Reality for Desktop Use
Burn-in happens when static UI elements (Windows taskbar, browser chrome, game HUDs) wear certain pixels faster than others. On TVs used for varied content, this takes 5-7 years. On desktops with static elements displayed 8+ hours daily? Faster.
Forum Experiences with OLED Burn-In:
Several members have reported concerns:
- “Visible taskbar retention after 6 months of heavy desktop use (coding 8 hours daily, white backgrounds)”
- “Game HUD elements (minimap, health bar) slightly burned in after 1200 hours of same game”
- “No issues after 18 months, but I’m religious about pixel shifting, auto-hide taskbar, and dark mode everywhere”
Mitigating Burn-In Risk:
- Enable Windows auto-hide taskbar: Static taskbar is burn-in enemy #1
- Use dark mode everywhere: Reduces pixel wear (white pixels work harder)
- Enable monitor’s pixel shift features: Moves image slightly to vary pixel wear
- Take breaks: Let screen go to sleep; don’t leave static images displayed for hours
- Vary content: Don’t spend 100% of time with same HUD elements in same position
- Avoid for primary work displays: If you stare at IDE or Excel 8 hours daily with bright white backgrounds, OLED burn-in is almost guaranteed
- Lower brightness: Desktop use doesn’t need 400+ nits; keep brightness at 50-70% to reduce wear
One member’s balanced take: “Using OLED as dedicated gaming display—no productivity work. After 1 year, zero burn-in. But I wouldn’t use it as my coding monitor with VSCode open 10 hours a day. I keep my IPS Black for work.”
OLED warranty in India typically doesn’t cover burn-in—it’s considered “normal wear and tear” or “user misuse” by most brands. Extended warranties from retailers also usually exclude burn-in damage.Exception: Some premium models now include explicit burn-in coverage:
- Dell Alienware OLED: 3-year burn-in coverage (verify in writing)
- MSI premium OLED models: Some include burn-in coverage (check specific model)
Always verify burn-in warranty coverage in writing before purchasing OLED for desktop use. Service center quality for OLED panel replacement in India varies—Dell and LG have better service networks than smaller brands.
OLED Power Consumption in India
OLED’s advantage: black pixels consume zero power. Disadvantage: bright content can consume more power than LED-backlit LCDs.
Forum member tested: “My LG 27GR95QE uses 40W displaying dark scenes (games with dark environments), 85W displaying bright content (white Excel sheets, bright games). My old IPS was steady 55W regardless. With frequent power cuts in my area, this variability matters for UPS sizing.”
UPS Considerations:
- Size UPS for peak power draw (bright content), not average
- 1000VA UPS minimum for OLED + gaming PC setup
- 1200VA+ recommended if running high-end GPU + OLED simultaneously
Best Use Cases for OLED
Choose OLED if you:
- Primarily game (70%+ gaming, especially single-player cinematic titles)
- Can afford premium pricing (₹80K-₹1.5L+)
- Take burn-in precautions seriously
- Want the absolute best image quality available
- Game in dark rooms (where OLED’s perfect blacks shine most)
- Can buy models with Gen 3 QD-OLED or newer WOLED (better text clarity)
- Have explicit burn-in warranty coverage (verify in writing)
Avoid OLED if:
- You do heavy productivity work with static UI elements (8+ hours daily)
- You code/write extensively and are sensitive to text clarity (consider IPS Black instead)
- You leave your screen on for extended periods with static content
- You can’t commit to burn-in prevention practices
- Budget is tight—better IPS Black/VA options exist at lower prices
- You need monitor in non-AC space (OLED generates more heat than LCD)
Mini-LED: The LCD/OLED Middle Ground
Mini-LED is standard LCD technology (IPS or VA) with a vastly improved backlight system. Instead of one backlight illuminating the entire screen, thousands of tiny LED zones can be independently controlled (local dimming).
What Mini-LED Solves:
- Better blacks than standard LCD (though not OLED-level perfect)
- True HDR with bright highlights (1000+ nits peak brightness)
- No OLED burn-in risk
- Better than standard LCD, cheaper than OLED
- Perfect text clarity (uses standard RGB subpixel layout)
Mini-LED Limitations:
- “Blooming” or halo effect around bright objects on dark backgrounds (cursor on black desktop)
- More expensive than standard LCD (₹40K-₹80K typically)
- Still not as good as OLED for pure contrast (zone count matters—more zones = less blooming)
- Higher power consumption than standard LCD (all those LEDs draw power)
Mini-LED Availability in India:
Limited but growing. Forum-discussed models:
- ASUS ROG Strix XG27UQR (27", 4K, 576 zones, IPS, ₹65,000)
- Cooler Master GP27U (27", 4K, 576 zones, IPS, ₹58,000)
- MSI MPG321UR-QD (32", 4K, 1152 zones, IPS, ₹75,000)
Forum feedback: “Mini-LED feels like 70% of OLED’s benefits at 60% of OLED’s price. Good middle ground if burn-in concerns you but you want better blacks than IPS. Blooming is noticeable with white cursor on black background, but in actual content (games, movies), it’s not distracting.”
Zone Count Matters:
- <300 zones: Noticeable blooming, marginal improvement over standard LCD
- 500-700 zones: Good balance, blooming reduced significantly
- 1000+ zones: Excellent performance, approaching OLED blacks in many scenes
Real-World Recommendations by Use Case
Gaming Only (Dark Room, Single Player Cinematic)
Best Choice: OLED (Gen 3 QD-OLED) > Premium VA > Mini-LED > IPS Black
- OLED’s perfect blacks transform cinematic games
- Take burn-in precautions (auto-hide taskbar, pixel shift, dark mode)
- Premium VA excellent budget alternative (Samsung Odyssey G7)
- Mini-LED if burn-in concerns you
Gaming Only (Competitive FPS/Esports)
Best Choice: Fast IPS (240Hz+) > Premium VA (240Hz) > Fast IPS (165Hz)
- Prioritize response time and refresh rate over contrast
- IPS has zero ghosting issues
- Samsung’s premium VA (G7) also works at 240Hz
- Avoid budget VA—ghosting affects aim tracking
Productivity (Coding, Writing 8+ Hours Daily)
Best Choice: IPS Black > Standard IPS > Everything Else
- Perfect text clarity (RGB subpixel layout)
- No burn-in risk from static UI elements
- IPS Black provides deeper blacks for dark themes
- Wide viewing angles for collaboration
- Avoid OLED—burn-in risk + text fringing issues
Productivity (Design, Photo/Video Editing)
Best Choice: IPS (factory calibrated) > IPS Black
- Color accuracy is paramount
- Look for models with ΔE < 2 out of box
- 99%+ Adobe RGB or DCI-P3 coverage
- Hardware calibration support (LUT)
- Avoid OLED—burn-in risk with static UI elements
Hybrid Use (Gaming 40% + Productivity 60%)
Best Choice: IPS Black > Standard IPS > Mini-LED > Premium VA
- IPS Black offers best balance (text clarity + decent blacks)
- Mini-LED if budget allows (HDR gaming + productivity text)
- Premium VA only if productivity is light (no 8+ hour coding sessions)
- Avoid OLED—burn-in risk with static productivity UI
Movie/Content Consumption (Primary Use)
Best Choice: OLED > Premium VA > Mini-LED > IPS Black
- Contrast ratio is king for cinematic content
- OLED provides theater-like experience (perfect blacks)
- VA is excellent budget alternative
- Mini-LED if you want HDR without burn-in concerns
- Standard IPS glow will annoy you in dark room viewing
Budget Gaming (Under ₹20,000)
Best Choice: Fast IPS (144Hz) > Avoid Budget VA > Avoid TN
- Budget VA ghosting ruins fast gaming experience
- IPS remains consistent across price tiers
- Look for: AOC 24G2, LG 24GN600, BenQ MOBIUZ EX240
- TN is obsolete—don’t compromise on viewing angles and colors
The Quality Spectrum Within Each Technology
This is the most important concept forum discussions miss: Panel type doesn’t tell the full story. Implementation quality matters enormously.
IPS Quality Tiers
Budget IPS (₹12,000-₹18,000):
- Example: LG 24MK430H, AOC 24B2XH
- Adequate color accuracy (95% sRGB)
- Noticeable backlight bleed (unit lottery)
- Basic build quality, plastic construction
- 1000:1 contrast, visible IPS glow
Mid-Tier IPS (₹20,000-₹35,000):
- Example: LG 27GL850, Dell S2721DGF, BenQ MOBIUZ EX2710Q
- Excellent color accuracy (98-100% sRGB)
- Minimal backlight bleed (better QC)
- Better uniformity and build quality
- 1000:1 contrast, IPS glow still present
Premium IPS (₹40,000-₹60,000):
- Example: ASUS ProArt PA279CV, BenQ SW271C
- Factory calibrated colors (ΔE < 2)
- Wide color gamut (99% Adobe RGB or DCI-P3)
- Superior uniformity (critical for professional work)
- 1000:1 contrast, minimal IPS glow
Premium IPS Black (₹40,000-₹85,000):
- Example: Dell UltraSharp U2724DE, ASUS ProArt PA279CRV
- All premium IPS benefits PLUS:
- Deeper blacks, less IPS glow
- Perfect for productivity + dark theme use
VA Quality Tiers
Budget VA (₹10,000-₹22,000):
- Example: Samsung F24T35, BenQ GW2480
- 3000:1 contrast (excellent blacks)
- 10-20ms response times
- Significant ghosting and black smearing
- Good for office work, terrible for gaming
Mid-Tier VA (₹25,000-₹35,000):
- Example: MSI MAG274QRF-QD, Gigabyte M27Q
- 3000:1 contrast
- 6-8ms response times
- Moderate ghosting (acceptable for casual gaming)
- Quantum Dot variants offer better colors
Premium VA (₹40,000-₹55,000):
- Example: Samsung Odyssey G7 (27"/32"), ASUS TUF VG32VQR
- 3000:1 contrast
- 4-5ms response times (with overdrive)
- Minimal ghosting (Samsung SVA technology)
- Often curved design (helps viewing angles)
- Excellent all-around performance
Common Mistakes to Avoid
Mistake: Choosing VA for competitive gaming without checking specific model’s response time and ghosting reviews
Instead: Research that specific VA model’s ghosting performance on RTings or TFTCentral, or choose fast IPS (safer bet)
Mistake: Assuming all IPS panels have same backlight bleed issues
Instead: Budget IPS has panel lottery; mid-tier+ IPS has much better quality control. Check model-specific reviews.
Mistake: Buying OLED for productivity-heavy use (coding/writing 8+ hours) without considering burn-in and text clarity
Instead: Use OLED for gaming only, or test text clarity in-person before buying. Consider IPS Black for productivity.
Mistake: Judging all VA based on budget model experience
Instead: Premium VA (Samsung Odyssey G7, ₹45K) performs completely differently than budget VA (₹15K). Not the same experience.
Mistake: Buying first-gen OLED (2021-2023 models) for text-heavy work
Instead: Look for Gen 3 QD-OLED (2024+) or newer WOLED panels with improved subpixel structure for better text clarity
Mistake: Buying TN in 2026 to save ₹2,000
Instead: Stretch budget slightly for IPS—viewing angles and colors absolutely worth it. TN is obsolete.
Mistake: Expecting Mini-LED to match OLED’s perfect blacks
Instead: Understand Mini-LED as improved LCD with local dimming. Blooming is inherent to zone-based systems. More zones = less blooming.
Mistake: Ignoring warranty coverage for panel-specific issues in India
Instead: Verify dead pixel policy, burn-in coverage (OLED), service center quality, and panel replacement turnaround time
Mistake: Assuming “144Hz VA” automatically eliminates ghosting
Instead: High refresh rate doesn’t fix slow pixel response time. Budget 144Hz VA can have worse motion clarity than 60Hz IPS.
