Up for sale is the Q58 case: bought sometime in 2022 and beeing using with custom cooled loop. Had to drill 2 holes inside to fit the pump, but it won’t be visible. Comes with pcie-4 raiser, have the og box. So shipping may not be problem except the cost. price is 5k + shipping
First msged in Dec 2025, msged several times later as a bit unsure if to buy or not and finally purchased in Jan 2026, requested to cancel shipping and reschedule for later, diverted delivery to neighbour on 9th Feb 2026 due to medical emergency, picked up from neighbour and checked in March 2026.
A bit disappointed with initial check. Will check again during build.
Was distracted and didn’t ask the usual questions about condition, etc given past deals with OP, their trader rep and no explicit declaration of any issues except the mod mentioned in sale thread.
Pros -
- patient, understanding and supportive
- good packing
- prompt communication and shipping
- bundled custom moulded hard tubing from previous WC build in the same
Cons -
- 1 foot broken, 1 foot loose/wobbly/broken
- PCIe cable slot mounting screw missing
- mobo screws, panel thumbscrews missing
- power cable socket screws, ssd mount screws missing
- fan hub panel gets unhinged when opened
- quite a few dings and dents on front panel
This was my mistake: didn’t realise the issue with loose foot, it was not broken though. And didn’t put the bags of screws in as I never use them and just throw them into a pile as have enough to manage and always think the end user will have which is again my mistake. Fan hub is something that can be fixed, it just is a hinge that needs screwdriver to make it work fine.
Will leave it to @BIKeINSTEIN to decide if he wants to keep it or not. Will take it back if the cons are not worth it.
