Hi there folks!
So, I’m looking to get a Lifepo4 + inverter based backup solution for PC and other stuff such as fans, lights, etc. The power cut happens randomly within a day but usually lasts from 10-30 mins, sometimes extending upto an hour but nothing major.
Since, I currently rent the place so I’d like to avoid getting a Lead Acid battery majorly due to their weight and maintenance part. So, I think Lifepo4 based solution would suit me better.
Max Loads would be in 300-400 Watts range at a time so I guess 1kVA inverter should suffice.
For battery I’m considering this
100Ah prismatic cell battery pack
with smart bms. Hope the bms used is JK in this because have heard not so great things about daly bms.
Now, I’m confused on the inverter part. I have heard things about your regular inverters with lifepo4 batteries that
- they won’t charge lifepo4 batteries to full
- they have trouble detecting the battery between power cuts and need to be reset everytime
I’d like to avoid such a scenario that’s why I’m seeking your help.
