Planing to get a wall mount for my monitor. currently have a LG 27GN800-B 27Inch and looking for a secondary monitor as well 1080 24-27Inch. let me know you suggestion based on your experience. P.S have desk wall mounted fixed.
The Amazon Basics model is a good pick and has lasted me across 3 monitor upgrades.
I have been staring on to this one doesn’t have much review.
looking for a one with Height adjustments
It should be okay. The wall mount plate looks a bit small, though. Make sure the weight of your monitor is within the supported range and you use high-quality long screws or fasteners.
