I’m gonna build a new PC for my friend soon, But I can’t decide on the cabinet.
There are only three requirements-
Can hold 4 or more HDDs.
Can handle 330MM GPU length.
Decent airflow to cool down the i7 with stock cooler(for now).
Budget is really strict can’t stretch anymore. Please suggest the best cabinet within the specified budget.
Thanks in advance.
NoobP
April 22, 2024, 11:12am
2
Was thinking of recommending ‘MAG FORGE M100A’ that’s at 3.5k with 4 argb fan, but then I read 330mm gpu as this cabinet has 300mm. Anyway, you can check out the Ant Esports cabinets like ‘Ant Esports SX7 Mid- Tower Computer Case’, and Galax rev 6.
Edit: Ant Esports SX7 Mid- Tower Computer Case is a-rgb and galax one is rainbow rgb
NoobP:
I already have sx7 supports only 2 hdds, and none of these support more than 2 HDDs.
The closest I could find under 5K was [CM Force500](’
https://mdcomputers.in/cooler-master-mid-tower-for-500-kkn1.html ’
) which can accommodate 8 3.5" HDD but the max GPU length is 320mm. Look for any of [this ](’
https://pcpartpicker.com/products/case/#sort=price&page=1&J=4,20&None=330000000,635000000 ’
)in 2nd hand market if possible
NoobP
April 22, 2024, 2:33pm
5
Sorry, my bad. And yeah, tried searching for one that meet all that requirements, but couldn’t find any weatsmile:
Friend already got a cabinet similar to this one, the HDD rack doesn’t let fit anything more than a dual fan GPU.
NoobP:
Yeah, guess have to compromise on the GPU length.
akaCode:
True. at that budget, you’d have to compromise on the bays or length. most of the ones that tick all your requirements are upwards of 5k.
I know corsair 100r is an old cabinet but it matches with your requirements and has an extra hdd slot.
[Here the link](’
Carbide Series™ 100R Mid-Tower Case ’
this does have enough space for anything but gonna be hard to find it .
This is a nearly 10-year-old case. Why recommend something that you cannot buy anymore?
NoobP
April 23, 2024, 5:55am
11
Idk how legit the site is, but it’s available in
Specifications: Steel ATX Mid Tower 2 x USB 3.0 / Audio Front Ports 2 External 5.25" Drive Bays, 7 Expansion Slots Combo 3.5in/2.5in x 4 Internal 3.5" Drive Bays, ATX (not included) Power Supply Technical Details: Brand Corsair Series Carbide 100R...
Price: INR 4,400
It can be found in local market too (second or new)
Trusted site and as far as I know they operate from Chenoy Trade Center, Secundrabad because they have stores too in that area.
