ITX Motherboards
Video : https://www.youtube.com/watch?v=l43GSBlr0dE
Web : https://sudobox.in/
Whtsapp channel
Specifications
N150 ITX Boards : V2.5G
Possessor : Integrated Intel®Alder Lake-N N100/N150 Processors
Graphics : Integrated Intel®UHD Graphics
Display : 1 x HDMI, 1 x DP
Memory : 1 x SODIMM, DDR5, 4800 MHZ
Storage : 6 x SATA 3.0 6Gbps, 1 x M.2 Key-M 2280, 1 x NVMe/NGFF 2280 (supports NVME & SATA)
Expansion : 1 x PCIe x1 slot
Backplane IO :
4 x Intel 2.5G ports
2 x USB 2.0 2 x USB 3.0
1 x Audio
1 x HDMI, 1 x DP
Onboard IO
1 x 24 PIN, 1 x 4 PIN - ATX PSU input
1 x USB2.0 pin (can be connected to 2 external USB2.0 ports)
1 x COM header 9pin
1 x CPU fan power header
6 x SATA 3.0
Front panel header
Front panel USB header
Size ITX
Color : Black (N100), Green (N150)
N150 ITX Boards : V10G
Processor : N150
Memory : DDR 5 SODIMM, 4800, Max 16GB (Intel officially supports 16G for N100/N150 cpus)
Storage :6 x SATA ASM1166 Chip, supports power management
SSD : 2 x M.2 Key-M 2280 (PCI GEN 3)
Ethernet :
2 x 2.5 GB [ Intel I226v ports]
1 x 10Gb (Marvell port)
Display : 1 x HDMI, 1 x DP, 1 x USB-C
FAN : 2 x SYS_FAN, 1 x CPU_FAN - PWM supported
Back panel IO
USB: 2 x USB-A 2.0, 1xUSB-A 3.0, 1 x USB-C
DP, HDMI, USBC
3 x LAN ports
1 x TF Card slot
Misc
2 x 5pin GPIO pin header
2 x 5pin COM
Motherboard size : ITX 170 x 170
Note
All items are new / unused
Dead on arrival - Will replace it with new item
7 Days testing warranty
See my other thread if you are looking for N100/N150 MiniPCs
Just ordered a N150 board. Have requested for shipping after diwali due to travel.
One of the 10G Version shipped to @ibose Tracking shared
Thanks for repeat purchase Ibose.
Payment received from @cyberwarfare for 10G version - shipping on hold for now.
ibose
October 27, 2025, 10:52am
5
Sorry for the delay. Board received and tested all ok . Leaving feedback.
Any recommendation for Case with this ?
Either 3d print, or look for ant esports vanguard
There arent smaller / itx size options right now
When is your all flash nas coming in ?
I have already received it, yet to take pictures / video
Working on getting a website up, so all information about all my items can be found there, and i dont have to answer people individually.
pa1
October 29, 2025, 6:09am
10
Does anybody have the idle power consumption numbers of this board without any hdd and just a single boot nvme/disk ?
Some forums say few chinese boards have quirks that cause far higher idle consumption than typical n100/n150 boards.
+1 im interested as well. someone if you could please share idle power draw and pkg c states info.
pa1:
far
@30fps101 is powertop output enough ? If not let me know exactly what you need me to run and i will share results. for C-states
The boards with ASM chip can go in deep sleep states
yep power top should be good
pa1
October 29, 2025, 2:17pm
14
I thought powertop is for battery powered devices ? I see wattage on laptop but minipc doesn’t give wattage results.
it still shows package c states, if all devices supports aspm we will see lowerc states. lower the cstates lower the power consumption.
for exact power figures as you said we need to measure at the wall.
Running 3 HDDs and 1 SSD
No optimization done
Let me know if you want me change some settings / optimize
@30fps101
Shipped 10G / N150 ITX board to @cyberwarfare Tracking shared, payment received.
Thanks
Received N97 boards Will post specs and benchmarks soon
Received the board and was able to test it yesterday. Works very well.
