need a compu range 40-50grands
hi
need a amd based system using socket 939s plz suggest a good system for gaming thank u
by the way plz tell the prices for each component i am frm mumbai range (40-50grands) thanks
refer this thread also
hi went to the post suggested but i am interested in a socket 939s system can compromise mouse and for present get a bit cheaper gfx card
Replace the rig mentioned with a :
  1. A64 3000 + Winnie
  2. Mobo Asus A8v dlx…
no point going for amd 3000 939 winchester if you don’t wanna oc , go 3200 winnie or read reviews of 3200 newcastle 939
why do you want 939?
do you want a agp based solution or a pci e based one ?
as someone already asked do you plan to overclock ?
for a gaming pc a good graphics card is more important than a high end cpu :wink:
Guys why don’t you allow him to go for an A8N-SLI del ???Thats far more future proof than any of the boards you have mentioned right?
Yep The one which I suggested is an AGP based solution. BTW 3000+ and 3200+ negligible performance diff, but a good diff in Price. Go for a Winnie 3000+ and it will oc without a sweat to 3200+ speeds. Infact Bottle out here has Oced it to FX 53 speeds..
Hardboy, let him decide what he wants ! and this is the last time i will be telling you to stop trolling in the forums !
Hmmm…40k to 50k
3000+ wud be fine if not great even if u dnt overclock.. 7.5
ati chipset …6.5
6600gt pci-e since board is pci-e…11.5 or 12
cabby nd psu 2.2k
17" monitor…5.5k
flat …7.5…but not sure..(posting the price for this frm one of the threads…so u better find out urself)
512 x 2 ddr 400mhz…4.5k
transcend…5.5k approx
well theres still room for the rest and that too a lot…
so if u have much left get a x800xl…much better and great price/performance.
and u can even get a 3200+ depending on the amount left.
ROCK ON
I still think you should cut down on some stuff and get the best motherboard possible like the A8N-SLI deluxe.
