Need a phone for mother under extreme budget
So, I need to buy a phone for my mother with an extreme budget between 8-9k.
She has a casual use case of youtube, whatsapp and other apps. There are some brands which she is not comfortable to have a phone from: Poco, Infinix, Tecno and Redmi.
Main Priorities: Must be smooth, have good enough camera.
If that’s the case then I can only think of Moto g35 which was available at 9999rs on Swiggy instamart last month.
Will see, It’s not that urgent but I have some time so I’m taking my time in selecting one. The phone you suggested is good.
Moto phones have bloatware and Moto G35 seems to be stuck on A14
Extend you’re budget a little a get a CMF phone 1, I saw one yesterday on Swiggy instamart for ₹13,999
If the budget is tight, then you might consider buying a second hand mobile, rather then buying a brand new one. Sometimes you may find good deals in classified section here itself. All the best.
Get a used flagship, something like the OP7/7T
Hmmm, haven’t used any recent Moto devices so can’t say whether you can remove/disable everything like we do in Redmi and realme devices. I had Moto g, Moto X(battery dead. Device still working), currently using moto g4 as a clock. My cousin bought it last month. His usage is similar to OP’s.
Isn’t it really way over the budget that OP specified?
If warranty isn’t a concern for you, I would recommend the same. You can find a device with better specifications within that budget. I didn’t suggest this earlier because I haven’t bought a single second hand phone, so…
Moto g06 Power/Samsung Galaxy M07 or A05/Lava Bold N1 Lite
Lava Storm Lite, but don’t expect much from the camera.
Buy her a Samsung. You can get good enough cheap ones for her Youtube and WhatsApp needs, and the Brand recognition will insulate your reputation against any future issues that may pop up.
https://dl.flipkart.com/s/4PJjFluuuN
https://dl.flipkart.com/s/4Pkrp!uuuN
I have come across these two.
Exactly - but most importantly - LET HER CHOOSE THE COLOUR.
Ofc, she’s going to use the phone. So, she’s in charge
If possible - give her the experience of ā€œIn-Hand feelā€ between both the models at an offline store and give her the illusion of choice (while subtly nudging her towards the better mobile) - making it so that her ā€˜agency’ is highlighted rather than your ā€˜recomendation’ - the ā€œchoiceā€ untimately will be hers. She will ā€˜protect’ her ā€˜choice’ against any future scrutiny/second-guessing from friends/relatives firecely. So your reputation as the ā€˜tech guru’ will remain unchallenged.
My mother uses CMF phone 1 and she does not have any complaints about it like all the previous phones she’s used.
She mostly uses it for Browsing, Shopping, Using payment apps and YouTube
The phone clicks pictures good pictures even if you shake your hand aggressively considering the fact that it doesn’t have any optical Image Stabilization :exploding_head:
Just buy a little expensive and cry about it once rather than buy cheap initially and cry forever
Couldn’t agree more with this
She now says to put a hold on buying the phone now and buying it when necessary
One of the issues with older flagship phones is the battery capacity and charging speed. I use a OP7 myself and its battery has weakened a lot, can’t use it without charging it fully at least once in a day. This is with almost everything turned off. Better to buy a used mid-range phone from a year or two back. Also the camera quality isn’t as good anymore.
Take mine 10k cmf phone 1
Get a LAVA Phone, i can swear by its reliability and good support in case something happens. Stock android too.
Source - Got me own mum a Lava phone and good so far for over a year.
This one should work - Lava Bold N1 5G https://amzn.in/d/093PLgj2
If budget can stretch, this can be good too - Lava Storm Play 5G https://amzn.in/d/02og2oIx
