My current one is a 1100VA APC unit which has been sufficing for 5 years. But now it dies the moment the current goes.
I remember someone on another thread recommending a Cyberpower 2200VA one, available on MDComputers for a little less than 8K, I think. Just want to know if there are any other options. There is an APC 2200VA one on Amazon which I would have bought if it wasn’t double the price of the Cyberpower. Even though I am partial to APC since the current one hasn’t given me any trouble so far.
Any reccos, suggestions or advice would be super helpful. Thank you.
Also, I did do a search for “UPS” but I guess that’s too short a term, so the results just return practically every thread.
Battery dealer as in car/bike battery dealer? Wouldn’t that be dangerous? Also, how much would they charge; if you could give me an estimate for budget?
Change batteries after 2 years!
You can order yourself or get it changed in a electronics shop. The batteries specs should be written on UPS itself or website and last resort is just to open it and see the batteries. But it should be two 7ah batteries as above comment has mentioned.
You’ll need two 7AH batteries. Should cost you around 1.8-2k including exchange of your current dead batteries at your nearest Exide/Amaron dealer. They will replace them for free.
Or when you feel like the backup has reduced by a lot and not sufficient anymore. UPS is essentially like home inverter but with faster switching time and voltage regulation built-in.
Thank you to everyone who took the time to help with this. Got the batteries swapped out at a dealer like you guys suggested. Saved me a chunk of money! Thanks so much!
