Need a Water Purifier for Senior Citizens under 15k
I suggest getting your water tested first and then deciding on a purifier. This will help you select the required purifying technology
We got the Mi Water purifier mainly because the installation was self-installed (super easy to do if you have a plug point, a free water inlet and outlet/sink) and even the once a year filter change (our tap TDS levels are hitting 1000) is self-changed. No “Service” required. This was necessary as we had gotten it during the pandemic.
And best part was that it can be both hung on the wall as well as made to free stand which was important for us as we live in a rented place and there were no nails to hang it from.
Have been running for the past 4-5 years without any issues.
https://www.mi.com/in/mi-smart-water-purifier/?srsltid=AfmBOoq78tmxrBHf97TZk8yWaYsd8f2cq8GPcHINiFRDemeJdL-alwV9
However, it is out of stock at the moment.
The urban company one seems to look similar to this and they claim provide free installation and 2 year no filter change guarantee. Perhaps you can try that.
I was wondering why everybody jumped in with suggestions without asking about the water supply.
this is a first for someone saying UV is not worth it.
