My Acer Aspire A515-45 needs a battery replacement. Current battery specs:
- Model: 16C AP18C8K
Wear level: 55.6% (battery is significantly degraded)
Replacement Options Found
I’ve found these two potential replacements online:
TPS Tech
https://www.tpstech.in/products/acer-ap18c8k-original-oem-4471mah-11-25v-4-cell-laptop-battery
Claims to be “Original OEM”
Specs: 4471mAh, 11.25V, 4-cell
Laptop Store India -
https://www.laptopstoreindia.com/acer-ap18c8k-internal-laptop-compatible-battery-price-in-india
**Questions
- Are these batteries compatible** with my Aspire A515-45? The part number AP18C8K matches, but want to confirm.
Which seller is more reliable? Any experiences with TPS Tech or Laptop Store India?
Better alternatives? Are there other trusted sellers in India for this battery? Looking for:
Good warranty (at least 6 months)
Reasonable price
Genuine/high quality cells
Installation tools needed? What screwdriver set should I buy to safely open this laptop model? Any specific size recommendations?
