Need One Plus 7t battery
What is the best way to get a OnePlus 7t battery. Local authorized service center does not have one and says that the product is end of life.
If this is for personal use, I am happy to see more people trying to use their electronics for a longer time. I hope right to repair becomes more mainstream in India.
I can’t vouch for this specific part, but I will vouch for the seller. Recently purchased a battery and back panel from them for a different phone that I changed at home, and the compatible products were of good quality, received in a couple of days through Blue Dart.
I didn’t go to Lamington Road in this instance, but they charge 150-200 bucks for any replacement in their shop.
https://www.mcarespareparts.com/products/mobile-battery-compatible-with-oneplus-7t?_pos=8&_psq=oneplus+7t&_ss=e&_v=1.0
thanks @@sama. How good is the backup you are getting, is it comparable to the original battery. Also did you happen to buy it for a fast charge phone and does it work.
Not for a fast charge phone. However, after a few charges, Accubattery shows capacity as 97-99% of the design capacity based on how long I charge it. Backup is fairly decent compared to the original one, though I wouldn’t remember since it has been a long time.
I recently changed 5t battery from authorized service center in gurgaon. So i guess 7t should also be available. You can check online also for price of it.
