Need suggestion for Wireless Carplay Adapter
I’m looking for a wireless CarPlay adapter for my Volkswagen Polo with the stock RCD330. I’m considering two options:
  1. Teeran 2-in-1 Wireless CarPlay - It’s slightly expensive (around ₹2.5k), but it has a good number of positive reviews.
  2. Wireless CarPlay Adapter - This option is more affordable. Even with an extended warranty, it would cost under ₹2k.
I’d like your suggestion on which one would be the better choice in terms of reliability and value for money.
I think all of them are built by the same Chinese factory. I think the one linked below might be “better” as it seems a more established brand. I have no experience with either of them. I have the OG: “AAWireless”.
Thanks but did you see the similarity between the two stuff i mentioned , Both were flat module which looks minimalist .
The linked design by you looks good if it fits. Go for the cheaper one. They are most likely made in the same place.
I’ve used 2 - the portronics one mentioned above and one by Dr. Vaku. Both work absolutely fine and serve their purpose :smiling_face:
I bought this one recently and i must stay that it is really good, it does connect very quickly, by the time i get inside my car and start it, put in reverse gear to get out of parking it has already connected to my S24.
It doesn’t protude at all like the other ones that stick out as sore thumbs, so this is better and sleek.
