Netgear Orbi TriBand 3Gbps Mesh plus Wifi Access Points galore
Netgear Orbi TriBand 3Gbps 8500/- (will not sell both keep either of these two)
Nethear R7000 … 6000/-
apart from above i have Professional Access Points
1.Cisco AP AIR-1815( controller not needed, works as independent AP, will help to configure)… 3500/- needs 48v adaptor. or Active PoE switch
2. Ubiquity AP AC ( 3500, one without cap 3000) will provide a 24v poe
3. Extreme Networks Symbol 7522 (AC AP dual band) very robust … Rs.3000/- needs 48v adaptor. or Active PoE switch
Send me offers through PM
PM’ed you.
bump! orbii retails for 14k
The cover says orbi add on satellite. Do we Need another router to work with this or can use existing routers like dlink?
Will only work with Orbi mesh AFAIK.
Rcvd and tested the R7000. Everything working well. Apologies for the delayed post. Feedback left. Request @@Zino to kindly do the same.
