Lots of media related questions, so here goes:
Often one of the most overlooked facets of CD/DVD burning is the media in use. People often go and buy generic 0.1c media, and then complain of data corruption and loss! The truth of the matter is that media DOES matter, and can often make the difference between your data lasting for 5 years and 5 days!
By popular agreement, the best CD-R media was made by Kodak. But this was before they announced that they were leaving the market in March 2001. As a result, they are really difficult to obtain, and really expensive too.
But Japanese manufacturer, Taiyo Yuden,also make excellent CDRs.In fact,they were the company that invented recordable CD-Rs, and started it all out. Taiyo Yuden holds basic patents on CD-R, but so do Philips and Sony. Although TY conceptualized and did the actual work to physically invent CD-R, Philips and Sony may be credited as well in its final development
http://www.oto-online.com/sept98/history.html](http://www.oto-online.com/sept98/history.html
Patenting History of the CD-R disc
The error rates on these discs from just about any burner are very low.Other well regarded manufacturers include Ritek, Mitsui, Moser Baer India and Mitsubishi/Verbatim. But some Verbatim discs are made by CMC in Taiwan, and these are not very good, to put it mildly. The Verbatim discs manufactured by Mitsubishi in Japan are very good. The only way you can differentiate between them while looking at the packaging,is that the Mitsubishi Verbatim discs are manufactured in Japan, while the CMC Verbatim discs are manufactured in Taiwan.
Mitsui have followed Kodak, and are now on their way out of the optical media market.
Errors on CDR/RW discs are measured in terms of C1 and C2 errors. At the most basic (and this really oversimplifies and glosses over a lot), the C1 layer corrects the most common errors, the C2 layer corrects âbiggerâ errors that make it past the C1 layer, and the third layer that is included in mode 1 and mode 2 form 1 discs consists of extra data bytes used for EDC/ECC. It corrects errors that get past the C2 layer. In an audio disc the drive will attempt to mask errors that get past the C2 layer by guessing what the correct value should be. More reading material may be found here:
http://www.cdpage.com/dstuff/BobDana296.html#3](http://www.cdpage.com/dstuff/BobDana296.html#3
http://www.mscience.com/faq13.html](http://www.mscience.com/faq13.html
Question about USIng Nero CD SPEED : CD-R/CD-RW Drives](Question about USIng Nero CD SPEED : CD-R/CD-RW Drives
http://www.roxio.com/en/support/cdr/cderrors.html](http://www.roxio.com/en/support/cdr/cderrors.html
http://club.cdfreaks.com/showthread/t-70201.html](http://club.cdfreaks.com/showthread/t-70201.html
Errors on DVDR/RW discs, on the other hand, are defined as PI (Parity Inner) and PO (Parity Outer) errors. They are roughly analogous to C1/C2 errors on CD-R/RW discs,
C1/C2 and PI/PO errors can be measured using KProbe.
Read about KProbe, how to use it and download it here :
http://club.cdfreaks.com/showthread...&threadid=92216](http://club.cdfreaks.com/showthread...&threadid=92216
Do note that PI/PO testing will only work on Lite-On DVD writers, and C1/C2 testing on Lite-On CD/DVD writers.It is recommended to scan at 4X speed/8ECC during PI/PO testing and 40X during CD-R testing.
Explanation of PI/PO errors
Download the ECMA 267 Standard for DVD-ROM, the ECMA 337 Standard for DVD+R/RW and the ECMA 338 Standard for DVD-R/RW at [
http://www.ecma-international.org](http://www.ecma-international.org/
) if you want to look at the standards for yourself. Here is some data from the ECMA standards (same for DVD-ROM, DVD-R/RW and DVD+R/RW):
Random errors:
A row of an ECC Block that has at least 1 byte in error constitutes a PI error. In any 8
consecutive ECC Blocks the total number of PI errors before correction shall not exceed 280.
Here we see what a PI error is defined as a row in an ECC block having 1 byte or more containing errors. And that the sum of PI errors in 8 ECC blocks after each other should not exceed 280 PI errors.
But what is a row and what is an ECC block? Again we refer to the ECMA standards. We do not copy and paste everything but if interested look in the ECMA standards. A row is 182 bytes long where the last 10 bytes contain PI (Parity Inner) information. An ECC block is 208 rows long where the last 16 rows contain the PO (Parity Outer) information. This gives us a maximum possible PI error amount of 208 errors per block and for 8 blocks after each other this sum is of course 8 times higher giving a maximum possible amount of 1664 PI-8 errors. In practical use a disc with 1664 PI-8 errors is unreadable.
According to our tests the specified max PI-8 sum of 280 for good discs seems to be a good guideline, as some readers have problems reading discs when the PI-8 errors is over 300 and most players starts to have problems when the PI-8 error level reaches 600 or more.
But what are the PO errors that K-Probe reports? Actually the PO errors that K-Probe reports is the Parity Inner uncorrectable errors, meaning errors left after PI correction. Only the ECMA 337 standard describes the Parity Inner uncorrectable errors. So how is a Parity Inner uncorrectable error defined? Here are what ECMA 337 states:
ââŹĹIf a row of an ECC Block as defined in 13.3 contains more than 5 erroneous bytes, the row is said to be ââŹĹPI-uncorrectableââŹÂ.ââŹÂ
In theory an ECC block may in the worst case have 208 PI uncorrectable errors since every ECC block is 208 rows long. But the ECMA 337 standard goes further and specifies the max amount of accepted PI uncorrectable errors allowed on a good disc:
ââŹĹ- In any ECC Block the number of PI-uncorrectable rows should not exceed 4.ââŹÂ
This is where K-Probe gives us problems as for PI errors it have to be set to a PI/PO sum of 8 ECC blocks to show results that compares to the standard, but for PI uncorrectable errors (Called PO in K-Probe) the PI/PO sum have to be set to a sum of 1 ECC block.
A guideline is to calculate the Parity Inner Uncorrectable errors to 8 ECC sum, which is max 32 (4 x 8 ) Parity Inner uncorrectable errors, but now we canââŹâ˘t be sure if one of the 8 ECC blocks exceeds the specifications. But if the result exceeds 32 PI uncorrectable errors we know that at least one block have more than 4 PI uncorrectable errors.
But what makes a disc unreadable? A PO uncorrectable error will make the disc unreadable, but K-Probe does not display the PO uncorrectable errors.
Notice that there are other aspects such as disc reflectivity, jitter, tracking errors and so on that also will affect the readability of a DVD disc ââŹâ but for this we do not have measuring equipment available.
And another note is that we have scanned the discs at 4X CLV speed, by lowering the speed to 2X(DVD-R/RW)/2.4X(DVD+R/RW) or 1X the amount of reported errors may drop on some discs. We scanned at 4X CLV due to lower speeds taking to much time.
To see if there is a connection between the reported amount of errors and readability of the discs we also include the reading curve from a JLMS XJ-HD165H DVD-ROM that seems to be pretty easy affected by the quality of a written disc.
Easier explanation on how to read the test results.
Maybe this got too technical, and you are wondering what to look for in Kprobe reports?
Use this as a guideline for good discs:
PI(Parity Inner): No larger areas on the disc should exceed 280 PI-8 errors, do not worry too much about high single spikes that exceed 280.
PO(Parity Outer): No large areas on the disc should exceed 32 PO-8 (actually PI uncorrectable) errors, do not worry too much about high single spikes that exceed 32.
And as always; lower is better
And look at the reading curve in CDSpeed or KProbe, a slight slowdown at the end is probably nothing to worry about, but huge bumps and slowdowns are not good.
Another error measurement software app: CDDoctor
Download/discussion :
Official CD Doctor (WSES alternative) Thread : CD-R/CD-RW Drives](Official CD Doctor (WSES alternative) Thread : CD-R/CD-RW Drives
Difference between DVD-R and DVD+R
http://www.answerbag.com/q_view.php/2279](http://www.answerbag.com/q_view.php/2279
What means DVD+R? - AfterDawn](What means DVD+R? - AfterDawn
http://www.cdfreaks.com/article/110](http://www.cdfreaks.com/article/110
http://www.cdfreaks.com/article/113](http://www.cdfreaks.com/article/113
Media Compatibility Threads
Media Compatibility With CD-RW Drives - Which Media Is Best? : Recordable Media Discussion](Media Compatibility With CD-RW Drives - Which Media Is Best? : Recordable Media Discussion
Media + Media Test Forum at CDFreaks
Sites To Visit.
The Media Sciences FAQ:
http://www.mscience.com/faq.html](http://www.mscience.com/faq.html
www.dvddemystified.com/dvdfaq.html
Jim Taylorâs DVD recordable FAQ.
www.cdrfaq.org (Andy McFaddenâs excellent FAQ site.)
www.cdrlabs.com
www.cdfreaks.com
club.cdfreaks.com
www.rpc1.org (best place for hacked RPC-1 DVD-ROM/R/RW firmware, and custom firmwares!)
http://www.computermusic.co.uk/tutorial/cds/cdmain.asp](http://www.computermusic.co.uk/tutorial/cds/cdmain.asp
http://www.dalmedia.com/recording_modes.htm](http://www.dalmedia.com/recording_modes.htm
http://www.burnworld.com/cdr/primer/FORMATS.HTM](http://www.burnworld.com/cdr/primer/FORMATS.HTM
http://www.osta.org/technology/cdqa2.htm](http://www.osta.org/technology/cdqa2.htm
http://www.pctechguide.com/09cdr-rw.htm](http://www.pctechguide.com/09cdr-rw.htm
Mike Richterâs primer (parts of it a bit dated but still useful):
http://www.mrichter.com/cdr/primer.pdf](http://www.mrichter.com/cdr/primer.pdf
Places to purchase media:
Many thanksto Ian,cfitz,dhc014,Inertia,CDRecorder,dolphinus_rex and MediumRare from cdrlabs.com for their help.
Media Available In India
MID = Media ID
Alright, here goes:
DVD+R/RW
IMation 4X +R/8X +R discs â MID RicohJPNR01 for the 4X discs (if it says Made In Taiwan).
8X +R â MBIPG101R04 (If it says Made In India).
In general, these are excellent discs, the 4X ones in particular can be oversped to 12X on many drives. Difficult to get though, stock up on them if you can.
Price - 42-45 rupees each (spindle).
Sony 4X +R Discs â MID RicohJPNR01 . Easily available at Lamington Road at least, same price as above, and same quality. BUY!
Moser Baer 4X/8X +R discs â MBIPG101R03/R04 MID. Good discs, warranty available on them, around Rs.30-40 each in a spindle
Sony 8X +R discs â MID SonyD11. Made by Daxon(Benq) in Taiwan for Sony. Decent discs, but quality may vary from disc to disc in a spindle. Run about 50 rupees each in a spindle. Recommended.
HP 4X/8X +R discs â MID CMCMAG.E01/F01. Not bad in the right recorders. Lite-On drives are hit-and-miss with them, NEC and Benq will do fine.
About 45-50 rupees each/spindle.
LG 4X/8X +R discs â Not sure, most probably Prodisc R01/F01. Quite decent in the right recorders, but YMMV.
Mitsubishi/Verbatim 4X/8X/16X +R discs â MID MCC002/003/004. Excellent discs, burn well in almost all drives. Can be purchased from Santosh - 9892522796. About 45-65 each/spindle.
Mitsubishi/Verbatim DVD+R DL 2.4X+R â MID MKM001. Best +R DL discs out there. Expensive - 350/400 each, jewel case.
Benq 8X +R Discs - MID DaxonAZ2. Decent discs, quite like the SOny 8X +R ones. Around 45-50 each in a spindle.
DVD+RW:
Sony 4X +RW - 130-150 each in a jewel case. MID = SonyS11. Excellent. Full Stop.. ensure it is Made In Japan.
Imation 4X+RW - 120 each/jewel case. Ritek MID I think, havenât tried these. Decent quality, but the Sony discs are better.
Mitsubishi/Verbatim 4X +RW - MID MKMA02. Around 120-150 each/jewel case. Excellent again, but the Sony discs are slightly better ![]()
DVD-R/RW
Sony 4X-R - MID Sony04D1. Decent discs, nothing special. Around 30-40 each/spindle.
Sony 8X -R - MID Sony08D1. Better, made by Daxon in Taiwan for Sony. Overspeed to 16X in Benq drives.
Iomega 8X DVD-R - MID: CMCMAG.AE1. Decent in some drives (Benq/NEC/LG), iffy in others (Lite-On). Around 45-50 rupees each in a spindle.
MBI 4X/8X -R discs - MID: MCC01RG20/MCC02RG20/FujiFilm03 (8X only!). Decent discs all round, some use Mitsubishi stampers and QA. Around 25-40 each in a spindle.
Samsung 4X/8X -R discs â MID OPTODISCR004/8. Not bad, especially in the Benq 1620/1640, but there are better discs out there.Around 25-40 rupees per disc.
Princo 4X -R discs â MID: Princo. Avoid at all costs. 'Nuff said.
Edgetec = Darky and Apo use these.. I need info on these, guys!
Mitsu/Verbatim 4X/8X/16X -R discs : MCC01RG20/MCC02Rg20/MCC03RG20. Excellent again, no overspeeding on most drives though.Similar prices to the +R counterparts.
Sony 4X -RW - MID Sony00009. Decent, about 100 each in jewel case.
Mitsubishi 4X -RW : dunno MID>never used them. ANyone?
