https://www.techspot.com/news/109563-samsung-follows-micron-sandisk-raising-dram-nand-flash.html
Buddy
They are not fake. I researched using AI and it says it isn’t fake.
Just register them in Patriot Viper website and see for yourself.
My T-Create Expert RAMs also seemed fake at 1st but after I installed them and pressed expo they ran like butter.
Just check them once in your PC using CPU-Z and if you think they still are fake you can sell them on olx.
When I ran that 9DE00349 code, AI gave the exact specs of the RAM as specified on that sticker of your RAM.
I don’t want to be rude, but please trust your eyes rather than upload to a LLM. One of ram modules physically can’t fit in a DDR5 slot, look at the contact points. one of them is a ddr3 module.
Looks like someone put the original heatsink on an old ram stick and returned it.
When you put the RAM Slots pic i understood it is not DDR4 . Before that i was also searching for the fakeness of the RAM
Good catch though before delivery
I am also getting DDR4 delivery today , took out old 4GB DDR4 and gave at home to compare before delivery
You are correct , just checked few of my stick, I always stick to clicktech to be safe.
what about the importers lable , Was it Anand infotech?
You have received 32GBx2 ?
Yes one of the kit is 32Gb X 2
Wow, good catch. I don’t think I would have been able to see it if I didn’t have a motherboard.
@bssunilreddy the heatspreader with sticker is original but the pcb has been swapped
First processors, then ssds and now memory modules are being swapped by scammers.
I have about a dozen sticks of patriot memory, they’re all from the seller mentioned, looks like customers are doing the swap.
amazon everything is getting swapped , seems Flopkart must have caught and laid off that corrupt staff which has been employed by Amazon
In last 1 week my 7 orders were missing . Whole 2025 I didn’t have 7 missing orders
Hope you tested your ram stick to ensure they are not fake and working fine ?
Yes ,Mines working fine , Went up to 3700Mhz by just 1 Click
Good shit man, now I’m concerned about my own patriot ram purchase. I purchased from Amazon and the seller is Official Patriot Memory Store. Is it safe?? I won’t be able to check ram until 5-6 days after motherboard delivery
Mine was crucial & Clicktech Retail
Just stumbled upon this thread and I cancelled my order, which was due to be delivered tommorow. Same RAM. Same Seller.
Fake rams had gotten picked up yesterday, refund credited today. Just FYI.
