PC Case Recommendation for shifting between places.
I will be shifting my pc this year.
Currently i have a full tower with [Cooler master K501L](’
https://www.amazon.in/gp/product/B00CY8RTHS/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
) , which is a full sized case.
I m in search of a compact case and also something light on the wallet.
Not looking for an sff build, but something that can be easily carried in trains or buses.(As compared to this monstrosity)
I would like to use all my current components. Right now i have a. [Deepcool gammax v2](’
https://mdcomputers.in/deepcool-gammaxx-400-v2-blue-dp-mch4-gmx400v2-bl.html
), [ b450m mobo](’
https://www.gigabyte.com/Motherboard/B450M-GAMING-rev-1x#kf
),[ corsair rm 650](’
RM Series™ RM650 — 650 Watt 80 PLUS® Gold Certified Fully Modular PSU
), gpu is a rx6700 with 2 slot thickness(i think), a 2.5 and 3.5 inch hdd .
Vfm and airflow are the only things i care about.
Thanks
Assuming you have matx motherboard, this might do it, Lian Li A3-mATX, recently launched…
Thanks, this looks like a good case for me, but it is on a bit pricier side.
I was hoping to get somethin around 5k mark.
Are there any alternatives from cheaper brands.?
Another alternative is the zebronics woodan (should be a bit smaller than Lian li)
Showing oos for now.
Edit- this case really looks good in my budget, lets see if its available on other websites.
There are also Sama IM01 clones like this Galax Rev03 which are smaller, while still supporting mATX. But check compatibility with your AIO etc first
https://eshoppingmantra.in/shop/galax-pc-case-rev-03-revolution-03-white-cabinet/
The Zebronics Woodan and Galax REV03 are both Sama IM01 clones and are 99% the same case.
Thx, will loon into it.
I dont have an aio, just a cpu cooler
