Portable monitor with vesa attachment facility
Hi guys…
Can some one suggess a great portable monitor that is at least 1080p 16” and can be attached with a vesa arm… most of the items I searched doesn’t have vesa screw mounts…
Currently I am using a millenium technology portable monitor 15.6“ for my productivity screen space offloading … that I am not so convinced with as it came with CFL back light… what is the issue with CFL back light although it doesn’t look as bad… more over the bit depth is 8 bit and they claim HDR with it like it is possible at each of these bs of 10 bit panel…
Thanks…
CFL dust at the back side of monitor… good or bad???
hey i have this 16 inch 2.5k 240hz MiniLED Portable Monitor for sale it supports 75x75mm VESA mount it can easily be attached to a VESA arm
Let me know if you are interested
Led is better as compared to CFL backlight… but is there any issue with CFL backlight… apart from being cheaper… I was thinking???
You might need to import one as everything is overpriced locally. For example, I have the following ordered to someone who will be bringing it with them and it cost quite a bit less than 12k.
It is not from Uperfect but another Chinese brand since they all use the same panels with different frames.
