Pulse Audio on Ubuntu.Working Fine for you?
Hmm..for surround o/p ,most sources claims ,enabling pulse audio server and adjusting gnome-volume-control does.and the steps in my posts describes the typical solution.
Pulse audio works excellent for me except that the slightly low volume ,which I need to resolve out(hda-intel).
pulse audio really is the suck. And I’m not bashing linux here
Linux Hater’s Blog: Pulse my audio :face_with_tongue:
No.what can we say about those who writes BS.Gnome/Kde/ applications and bindings needs time to completely compatible to Pulseaudio.I see most of the applications are; .
and One must not whine and call “suck” when Developers like Jarosalov Kycela and others does their Hard work to write drivers under ALSA for most audio cards and in some cases reverse engineered too.Heck ,if some top end card vendors(creative,auzentech) don’t want their GNU/Linux users to have support for their Hardware -then it is a problem with the attitude of these corporations.
and before whining ,One must know how many drivers Linux Kernel carries purely on community support and by some neutral corporations who don’t mind the wrath from demon(m$)!go through the kernel compiling setup ,you know what a wonder Linux kernel is!It supports much more than what any other operating system supports.I know ,I know - window$ got excellent support by h/w vendors.you pop-in cd/dvd and there you go.
PS: so ,the freaks want to pollute every Linux thread? :confused: even Q&A types?please don’t put such offtopic threads here.heck ,everyone expects a flamewar wherever I discuss GNU/Linux.Isn’t it? :x
Gentoo-Wiki is a General Source for GNU/Linux Help :
Here ,about Pulseaudio:
PulseAudio - Gentoo Linux Wiki
Why would anybody need PulseAudio?
That’s a very common question as of lately, and somehow I feel like most people who haven’t dealt with ALSA in the past would find it very difficult to properly answer to it. Even myself I would have ignored one particular issue till last night, when I hit another reason why I want to keep PulseAudio as my main and only audio system as soon as possible, reducing direct ALSA access.
With modern systems you mostly get onboard sound cards, rather than PCI cards and similar, unless you’re somewhat crazy and want a proaudio card (like I did) or a Creative card (not yet sure what’s the fuzz about that). To be honest, my motherboard really does have a limited soundcard so I would have needed a PCI card anyway to get digital S/PDIF output, and I want S/PDIF because the room has too much electric noise to the point I can hear it on the speakers.
Somehow, ALSA seem to hide to most users that there are indeed a lot of limitations with the HDA hardware. This because the idea for the HDA was probably to shift as much work as possible into software space rather than doing so in hardware; this is why you need a driver fix for the headphones jack to work properly most of the time. While this can be seen as a way to produce cheap cards, it has to be said that software always had to compensate for hardware defects since it’s more flexible. And having most of the processing done in software means that you can actually fix it if there is a bug, rather than having to find a workaround if anything.
So, no hardware mixing, and ALSA has to use dmix, no hardware volume handling, and ALSA has to use softvol, no hardware resampling, and ALSA has its own resamplers, and so on so forth. But while ALSA has to cope with doing these things in the same process that are doing the audio output, and thus is not so good at coping with different processes accessing the audio device with different parameters.
Having a separate process doing the elaboration does not mean that you add more work to the system, you can actually make it do less work if, for instance, you ask that process to play a (cached) sound rather than having it opened, converted, and played back.
At the same time, the fact that PulseAudio handles mixing, volume and resampling in software does not mean that it adds to the work done by the software for most cards, since the most common cards nowadays, the HDA-based ones, already do all that in software, just you don’t see that explicitly because ALSA do them in process.
In my opinion, ALSA is really doing way too much as a library, since each time you open a device it has to parse a number of configuration files, to identify which definition to use (and even then, by default they are far from perfect, for instance for the ICE1712-based cards, which depending on the way they are wired may have two, four, six or eight channel outputs, the definition only suits the 8-channel model, and does not make sense with the lower end cards). And once it found the definition it has to initialise a number of plugins, internal or external, to perform the software functions.
And this is all without putting in the mix the LISP interpreter that alsa-lib ships with (I’d leave to Lennart to explain that one).
So if you think that PulseAudio is an over-engineered piece of software that performs functions in software that should be done in hardware, you better be a FreeBSD user. At least there the OSS subsystem does not try to do all the things that ALSA does (and on the other hand FreeBSD is trying to go the Microsoft way for the HDA cards, implementing the UAA specifications rather than having a huge table of quirks; as far as I can see that would be quite useful, if it’s going to work that is).
But even in that case you should probably find PulseAudio a good thing since it tries not to be Linux-specific and thus would allow for performing all the needed functions with a single cross-platform software without having to reimplement it in platform-specific systems like OSS or ALSA. That was my main reason to look into PulseAudio when I was working on Gentoo/FreeBSD.
For everyone who cares about users, let’s try to work all together to make PulseAudio better rather than attacking Lennart for trying to do the right thing, okay?
Flameeyes’s Weblog : Why would anybody need PulseAudio?
To be honest, I really am not interested in what it does or how it does it. I just want it to work out of the box without issues. Is it so hard ?
We have come to a point where apart from networking ( i guess thats always a tricky thing) , everthing else works flawlessly in a default ubuntu install. After pulse audio was implemented, audio has been added to that list. I dont think thats a good thing.
I’m just a humble linux user who wants his OS to work right :face_with_tongue: . Just because we love something doesn’t mean we have to be blind to its faults
For “just a regular user who wants his OS to just work” you would normally recommend they stick to an older/stabler release, and we have Ubuntu’s “LTS” (long term supported) releases like 8.04, but then again they made some risky changes (I think pulseaudio was in there too) which cause a lot of grief for many users. Maybe 7.10 is a good one to stick with, but that will soon be outdated (no updates).
This time I’m hoping they learn and use the 9.04 and 9.10 releases for a little experimentation (cutting edge features and bling) and the next LTS 10.04 release is a real stable (and easy) OS for the masses…
After all, it is to be expected to have incremental fixes/improvements with a short 6 month release cycle compared to Windows’ 3 yr release cycle… now we see openSUSE is moving to an 8 month release cycle to help with quality…
well ,I stopped a 2 year experiment(when my hdd died) of running Debian Sid with apt-pinning to experimental and testing repository and with few other unofficial repos - the experience is good.but I end up reporting to Debian BTS atleast 2-3 times a month.dpkg --force-overwrite with broken packages was common.So ,I hope jaunty experience will not come near to it;still with daily updates and all will be a bad experience :face_with_tongue: .
so ? 8.10 FTW!
BTW a few people (i have yet to try it myself) on the Jaunty 9.04 ubuntuforums section are reporting better results with the testing version 0.9.15 of pulseaudio, too bad it wont (i think) make it in for 9.04…
edit: interesting forum post which has some info about distro kernel latencies from the PA developer: Ubuntu Forums - View Single Post - Pulseaudio 0.9.15 testing preview
I have shared info on script from ubuntuforums to upgrade Intrepid Ubuntu’s Alsa to latest alsa-1.0.19 version inorder to fix HDA Intel Sound issues in below thread:
http://www.techenclave.com/open-source/gnu-linux-tips-and-tricks-129757.html
Seems like they’ve addressed the low-volume issue with a kernel fix - at least with today’s 2.6.28-11 updates to Jaunty alpha. Still got some crackling though.
OK there was a “call for testing” email: Large files under ubuntu do not appear to work
So I tried the special kernel and it resolves audio issues in Jaunty… working smooth for me now on my desktop and tablet :slight_smile: : https://lists.ubuntu.com/archives/ubuntu-devel-discuss/2009-March/007541.html
Is this bugfixes upstream on kernel or just Ubuntu’s version? :confused:
i believe the bugfixes are going upstream for both pulseaudio and kernel… an ubuntu dev just provided a deb for easy install and testing…
here is the patch in linux git repo waiting to be merged: git.kernel.org - linux/kernel/git/tiwai/sound-2.6.git/commitdiff
hmm.. 2.6.29 kernel hopefully contains that?
The patch is queued for the .30 kernel I believe, but Ubuntu (at least) has already backported it to the .28 they will release with…
