Quick Guide: Sizing Up And Selecting A Mikrotik Router
Yeah, you would not believe the number of intrusions I saw when I temporarily turned on logging for blocking incoming connections from WAN, it’s crazy.
I got one of these from @smnrock, and replaced my hap ac2 and a small 5 port POE switch with the RB5009 UPR. Working great so far.
I did consider one but the Hex is more than enough for the features I need and the bandwidth I have. Really top of the line hardware, the RB5009UPR
Try crowdsec and fail2ban.
I’ve heard of those and I still need to look into them but I think It’s way better with Mikrotik.
Basically, a simple firewall filter that blocks any new incoming connections to the router itself that didn’t physically originate from the LAN interfaces
Sheer elegance:
/ip firewall filter add action=drop chain=input in-interface-list=!LAN
And then Wireguard or Tailscale for services that you do need to expose to the internet.
Wireguard(if using mikrotik bounce servers) or tailscale are not internet/dmz.
So you don’t need anything special unless you are opening a port. Make sure ipv6 is disabled on lan if your isp supports it or add rule for that as well.
Fail2ban can give extra later of protection if a lan device somehow gets compromised and uses brute force attack on ssh port of your servers. So it can ban local as well as wireguard ips.
That’s the beauty of RouterOS/mikrotik, even decade old devices can continue to work with latest releases without sweat :slight_smile: Except container(restricted to arm64) feature, all other features should working perfectly fine in the older devices.
One issue I faced is that Interface Lists do not support VLAN interfaces. The default rules use Interface Lists everywhere and I had to write custom rules.
Input blocking excludes dstnat, so opening a port should not need any new rules, right ?
It is supported.. What exactly the issue?
I could’t find the VLAN interfaces in the selection. I will check it again once I reach home
Yeah, I haven’t publicly exposed ports/services since the ICQ days.
Theoretically, VLAN isolation should help with compromised LAN devices but I guess once something is already in your lan, or a lan device is compromised, then you have bigger issues to deal with.
I do need to figure out better network security some day.
I can see it now in the list. I was in an older release before doing netinstall. Did this feature come in a recent release ?
Not sure about RoS 6.x, but it was there from 7.x!
I was on 7.x, which one I am not sure. Thanks for clarifying
Yet to put the Hex back online. Went back to Openwrt on ERLite-3 for now till I fix this
Replaced rhe power adapter so its not the cause ..
Happy to ship
What I meant is that a full firmware refresh using netinstall will fix most issues. My case was triggered by the faulty power supply, but it still needed a netinstall.
