Reasonably priced universal wireless charger
Please help me find a reasonably priced universal wireless charger for Apple watch, galaxy watch and phones
You wont find a universal option. They have opposite magnetic patterns and probably different protocols too.
It’s ok if two different charging slots are there but should be in one setup.
This cable thingy is getting irritating.
I basically want to keep the charger setup at one place to charge the watches and phone
What phone models do you use. iPhones or Android ones.
Because if iPhones + Apple watch + Airpods. They do have such setups.
But if using Samsung + Apple watch + Airpods have limited options.
For some reasons Samsung watch and other such watches have limited options.
I can think of
[Satechi Trio Wireless Charger](’
https://satechi.net/products/trio-wireless-charging-pad?variant=32008960573528
US 120$ MRP. Indian variants are way off budget.
But there are some alternatives on Amazon.in like
https://www.amazon.in/Dailyobjects-Wireless-Charger-Transmitter-Coil-Compatible/dp/B09SFZ7DCP
[Baseus Smart Usb 3 In1 Sleek Design Fast Charging Wireless Charger For All Cellular Phones, Watches, Pods](’
Amazon.in
[UNIGEN UNIDOCK 3-in-1 Wireless Charging Station |23W Type-C PD](’
Amazon.in
I have no idea on how well the product are.
I would suggest you to use some multi port charger and plug in all different cables in a seperate table and allow others to use it. My host office had one such sleek setup with magsafe devices and other end having QC enabled devices. Some one used to plug in mi watch charger into one such port and was using it during break.
