Recommendation for a good 20000 mAh Power Bank
This one out of stock now.
I have been using Ambrane 20000mah for a year ( bought from Blinkit )
I bought an Ambrane 100W 25000 mAh power bank, and it has changed how I view power banks. I can charge my laptop and my phone using it, so I almost never run out of power. The 100w makes charging laptops so convenient, and it really helps in the situations where your laptop is running out of charge, and you just need a bit more to get some work done. Do check out high wattage power banks if you haven’t purchased yet. Link to mine:
https://www.amazon.in/Ambrane-Charging-Powerbank-Delivery-Powerlit/dp/B0BYVDM93V?sr=8-18
My experience , I brought xiaomi 4i (33w max) around 7 months ago , 2-3 month of usage it fell down from my sofa and started to behave abnormally, the impact was not that strong still.maybe maybe it’s connecting got lose or something, didn’t tried to get it fixed brought from a different brand
Why dont you guys take a chance with warranty. Just tell them its not working.
They will most likely replace it .
I don’t have kept the box and the documentation it has with , and in the amazon invoice it doesn’t even mention serial number, So no way to identify it’s the same .
Would they it replace regardless ?
Yes. just show them the invoice and btw Amazon might have something like Warranty slip which usually has serial number too.
It is in the same page where you download invoice. Just check once.
Anker 20000mah is really good if you are ready to spend the money. I bought it because other power banks used to take forever to charge, this one charges from 0-100 under 2 hours with 65W charger
Anker, while pricier than others, offers great quality(same for their cables and chargers)
Mi is the best vfm while still being good.
Usage of Ambrane PB caused some problems for a friend’s phone a few years back.
Personally- Would go for anker if budget permits else Mi (have used both - both worked flawlessly)
