need intel built only.. and config already mentioned just need suggestions regarding which option to choose from above options and any specific model for motherboard and ram which fullfills mentioned requirement
It’s still a difference of 3k+. Would it make sense to go for a cheap AIO instead of a good air cooler?
13600K/14600K are still 125W cpu, which can be handled by air coolers
Sorry…Actually I really dont know too many people here… would be really happy to get suggestions from you and also if you know someone who can guide pls tag them..
yes need type c port atleast 1 in back and front connector type c along with that
yess need wifi moterbaord
some options are - b860 tomhawk , b860m mortar, b760 tomhawk, b760m tomhawk, any other than this budget 18k to 22k
no such budget for ram but dont want to exceed too much, shoudl be vfm ram, need good mhz and cl ram for fast perormance and no rgb requirement bcz no gaming need
if not samsung can i go with wd sn850x or crucial t500 or any other gen4 2tb ?
cabinet- need argb fans so that can turn off and control light if want, mid tower will be good as will take less space, btw does mid tower supports atx motherbaord or only matx motherbaord, yes need type c port - max budget 5k afterr all off
psu - no gpu req, and even if any gpu taken after 3 or 4 years it will be mid tier gpu like 4060ti or 5060ti types not high end one. so i think 650w psu will be max to go not more than that required i suppose
From my experience with my 13700K+14700K with a contact frame and a 360 and a 420mm AIO..
Even a 360mm isn’t able to handle these processors at full throttle.. shader compiling and cinebench pegs them to 100 C Instantly.
Might be different for 14600k.. but 3k is too little to skip on cooling.
It seems for AM5 it doesn’t really matter what cooler u get the IHS design is quite bad.. a AK400 and my 420 AIO gives more or less the same temps.. but for intel.. to get the max sustained boosts cooling matters.
ohh..wasn’t aware of it…feels like ultra processors are one u r talking about..but i think ultra are for compact and power efficient systems and all in one and laptop not for high end pcs right ?
