Research & Review - Divx DVD Karoke Player Philips DVP642K
**DVD/Karaoke Player DVP642K/69
You have it, we play it! **
Dreaming of a player that plays practically any disc format while enjoying
flawless, true-to-life picture quality? Now you can! With Philips DVD players,
indulge in great movie and music entertainment experience delivered right to
your home.
**Target Audience :- ** All looking for a Gr8 Economical Standalone Divx DVD Player.
Note:
  • I have not purchased this player but review it at my friends → friends place
    so some of the images have been taken from the net as that guy was not
    allowing me to take pics of the inside and back part of the player.
  • Research compromoses of a 4Months of Reading from many many websites
    and i dont recollect properly how many websites i scanned & complied my
    data.
Some Important Sites that made this possible.**
Help from VideoHelp.com , Doom9.com Forums , Ryan.com.br , Divx.com Forums
Thanks to all the people at these place for taking time to answer all my
queries and helping me in writing this review. Without your help this would
not have been possible. Hoping that you will like my effort at writing such a
research & review
**Features **
**Picture/Display **
Aspect ratio : 4:3, 16:9
D/A converter : 10 bit, 54MHz
Picture Enhancement : 4x Video Upsampling, Progressive Scan, Smart Picture
**Sound **
Crosstalk (1kHz) : 105dB dB
D/A converter : 192KHz/24 bit
Distortion and Noise (1kHz) : 90dB dB
Dynamic Range (1kHz) : 90dB dB
Signal to noise ratio : 90dB
Sound Enhancement : Smart Sound
Sound System : Dolby Digital (AC-3), MPEG2, Stereo
**Video Playback **
Compression formats : Divx 3.11, Divx 4, Divx 5, MPEG1, MPEG2, MPEG4
Disc Playback Media : CD, CD-R, CD-RW, DivX, DVD, DVD+RW, DVD+R, DVD-Video, MP3-CD, MPEG4, Picture CD, SVCD, Video CD
Disc Playback Modes : A-B Repeat, Disc Menu, Fast Backward, Fast Forward, OSD, Pause, Screen Saver, Standard Play, Zoom
DVD Region : 3
Loader Type : Tray
Number of Discs : 1
Video disc playback system : NTSC, PAL
Video Enhancement : Progressive Scan, Smart Picture
**Audio Playback **
Compression format : Dolby Digital, MP3, PCM
Disc Playback Media : CD, CD-R, CD-RW, MP3-CD
Disc Playback Modes : A-B Repeat, Next/Previous Track Search
MP3 bit rates : 32 - 256 kbps
MP3 sample rates : 32, 44.1, 48, 96, 112, 128, 256 kHz
**Still Picture Playback **
Disc formats : DVD+R/+RW, Picture CD
Picture compression format : JPEG
Picture enhancement : Rotate
Rotation : 90 degree steps
Slide show : yes, with music (MP3)
Zoom : Yes
**Connectivity **
Digital audio out : cinch, coaxial, optical
Other connections : ComponentVideo out Progressive, Composite video (CVBS) out, DVD 6 Channel, S-Video out
Output rear : Audio L/R out
**Convenience **
Child Protection : Parental Control
Convenience Enhancements : On-screen Display
Display Type : FTD
Ease of Use : On Screen Display
On-Screen Display languages : Chinese, English
Remote control type : 3141 017 90181
**Accessories **
Included Accessories : Audio/Video cable, Batteries for remote control, Remote Control
**Green’ Specifications **
Lead-free soldered product : Yes
Packaging material : Carton
**Dimensions **
Packaging depth : 306 mm
Packaging height : 128 mm
Packaging width : 510 mm
Packaging type : D-box
Product depth : 235 mm
Product height : 43 mm
Product width : 435 mm
Product weight : 2 kg
Product weight in lbs : 6.6
Weight incl. Packaging : 3 kg
Weight incl. packaging in lbs
**Power **
Automatic Power off : SmartSave
Power Consumption : < 10W W
Power supply : 110-240V
Standby power consumption : < 0.8W
Cost:- Rs5990
In Chennai they give 8 Hindi + 2 Cartoon Movies Free with it.[Check it at other places]
[break=Pictures]
Images
The Box
The Player
Remote Control
Back Connectors
Back Connectors with Cables
Another Picture
TV Display
[break=What’s Inside]
A Peak into whats Inside this Player
Image Taken from Ryan.com.br as no one would allow me to open his player
**ESS VIBRATTO-II CHIP-SET **
**Supports **
Video Decs: Mpeg4 with B-VOP (with or without packed bit-stream)*
Audio Decs: MP3 (Mpeg1/2 Layers 1, 2 and 3), AC3 (Dolby® Digital), WAV
Containers: AVI and MP4 container (Audio: MP3, WAV, AC3)
**Does not support **
Video Decs: Qpel, 3 warp-point GMC
Audio Decs: AAC-LC and AAC-HE
Various: PAR or DAR signalling, encoded within the Mpeg4 bit-stream.
  • Based on using the DivX codec. Confirmation with other codecs is required.
PLAYER MANUFACTURERS USING THIS CHIP-SET
Players/Model Numbers
Philips: DVP630/00, 630/02, 630/04, 630/05 | DVP632/00, 632/02, 632/04, 632/05 |
Philips: DVP640K/69, 640K/75 | DVP642/17, 642/37 |
Xoro: HSD 310 | HSD 415
JVC: XV-N316/315
[break=Samples Tested]
**Samples Tested **
** By Me**
Divx 5.1.1 1000kbps + MP3 128Kbps - Home Theatre Profile [Works]
Divx 5.1.1 1000kbps + AC3 - Home Theatre Profile [Works]
Xvid 900kbps + MP3 128Kbps [Works]
Burnt on DVD+R
**Others Tests Taken from Net **
**Person 1 **
DivX 1B-VOP - which is “packed”, seems to work
DivX mB-VOP - which is “not packed”, needs confirming
XviD 1B-VOP - “packed”, seems to work
XviD 1B-VOP - “not packed”, needs confirming
XviD 2B-VOP - “packed”, needs confirming
XviD 2B-VOP - “not packed”, needs confirming
Nero 1B-VOP - “not packed”, seems to work
**Person 2 **
1 SMR w/ 96kbit CBR mp3
10 Divx 3.11 :wink: Low-motion w/ 96kbit CBR mp3
450 Divx 5.0.5 - 5.1.1 slow psychovis, GMC, B-frames w/ 128bit VBR mp3
30 XVID 1.01 - 1.02 generated with AutoGK in .ESS mode, w/ 128bit VBR mp3
I particularily didn’t expect the GMC’d divx files to work. But they did! Every last encode worked flawlessly. Even the SMR! This thing is beautiful, well worth the $62. The only complaints I have have all been noted before:
  1. Letterbox / widescreen movies have a strange wiggle to the bottom scanline.
  2. A lot of how good mpeg4 looks has to do with postprocessing (deringing, deblocking).. This thing doesn’t do those things.
  3. The 3.11 divx is choppy. The motion stays in sync with the sound, but it all has a not-full motion look to it. I’ve noticed similar problems trying to play them with the modern divx decoder. I really can’t remember, this could have been a problem with flaskmpeg or the low-motion codec. Anyways, not a biggie, I sure don’t encode these anymore.
  • None of the Philips players support Qpel or GMC
Where to get test samples
For all those who would like to test an Mpeg4+Mp3 encode in MP4
http://homepage.ntlworld.com/seemoredigital/XviD+Mp3+Subs.zip
[break=Q & A]
**Questions & Answers **
Q: Why is this player so expensive when Philips sells their own other DVD player’s for fraction of this price?
A: This player is positioned at top end of entertainment hierarchy of Philips. It supports Progressive scan (NTSC and PAL) for better quality, it plays Audio CD, Video CD, SVCD, DVD, Karaoke, DVD+R, DVD+RW, MP3, JPEG, Divx 3.x/4.x/5.x, XViD, DVD-RW abd DVD-R media/formats. No other player available officially as of today in this country offers so exhaustive list of format and media playbacks. On back of player you will find all possible connections for connection to any audio or video systems you may own. It can plug to TV using Component Video (with 3 RCA cables), or S-Video or Composite Video. It has built in Dolby Digital and DTS decoder. Best part is, this player is more of computer and can be regularly upgraded with firmware updates available from www.philips.com
Q: Will spending extra on DVD player which supports Divx/XViD movie format will I save any money in future?
A: Yes, Divx movies can fit in single CD-R quality is close to DVD, supports subtitle. Divx/XViD movies usually fit in one CD and will cost you price of single CD-R. Apart from money, you will need much less storage space for your collection of CDs.
Q: Will Hollywood studios release movies in Divx format?
A: Unlikely. Hollywood doesn’t like piracy and Divx/XViD is very user friendly and very easy to copy. There is VOD (Video On Demand) format in Divx where by you can download movie with credit card and buy license for watching it for week or month on your Divx certified DVD player. But very few movies are available as of now in this format.
If Hollywood did embrace this format, you can expect huge change in way we rent movies. Just imagine Netflix sending you custom made VOD Divx movies to you which will play for week or month only on your player and you don’t have to return it back. It will change economics of movie rental business. Right now there is huge cost involved in returning DVDs which we rent and also queue for popular movie titles where by you don’t get DVD till others before you in queue has seen movie and returned it. With Divx VOD every customer can be provided with custom made VOD CD without any queue.
Q: Which other brands like Sony, Samsung, LG are selling Divx capable DVD Players?
A: Philips has launched this player and its variants all over world and is first major brand to do so. Why does Philips put its worldwide muscle behind Divx format? Why didn’t consumer electronics giant Sony do it? One reason I can think of is that Philips doesn’t own any Hollywood studio’s and hence doesn’t have any conflict of interests and can just offer consumer latest and best available technology without worrying about feelings of Hollywood studios. Other brands like Kiss Technology, Avayon, RJTECH has also launched Divx capable DVD players but they are not available here.
Q: Where can I get Divx/XViD encoded movies?
A: If you already have DVD or access to DVD of any movie, you can use Gordian Knot available at www.doom9.org or and convert your movie to Divx format. You can also download movies encoded by others in Divx from P2P. But when you do this, you may be breaking copyright laws if you are downloading or copying movies.
Q: Anything else we need to know before buying Philips DVP 642K?
A: This player lacks good DISPLAY function and you can’t find length of movie or remaining movie’s duration on screen, only duration of movie already seen is displayed. This is major drawback and Philips should be able to rectify it in next firmware update. Their remote though small and cute uses lot of keys for dual functions. There is no Open/Close button but STOP button pressed for 2 second will do that job. There is no Rewind or Forward button but direction keys for menu system would do that.
Q: Is this player region free? Will it play all DVDs?
A: No, out of box it is locked to one region, but in 2 seconds by pressing few codes on remote control, you can make this player region free.
Q: Is Philips DVP 642 and DVP 642K same player?
A: No, they are different models. You will find only one of this two in any country. In USA it is DVP 642, in some Asian countries including India it is DVP 642K. Both the players are physically different. DVP 642 doesn’t have Karaoke function; DVP 642K has Karaoke function. DVP 642 when I tried with firmware update, it played subtitles, DVP 642K doesn’t play subtitles. Both players are 110-220V compatible and will work anywhere in world.
Q: The new firmware 0531 promises external subtitle support for divx movies.
I have tried to play movies with .srt subs. The player does not display them.
A: Make sure from the file menu, you select the .SRT file first, and hit OK.
You should get a message to the effect of ‘Divx Subtitle file selected’.
Then select the movie file itself.
**Tips & Tricks **
To Play Movies with Bitrates above 2000kbps & DVD Resolution burn the movies on a DVD than on a CD
as in a single rotation more info can be read from a DVD than a CD.
**How do you prepare the CD/DVD for the Philips DVP642 **
  • Around 6 to 8 XVID/DIVX movies 1 DVD+R 4.7G disc.
  • Burned as data (joliet) Mode 1 just like mp3’s.
  • AC3 are supported and if you use a DIVX certified template for encoding, the movie will always play.
  • Some Xvids need to be tested first and in general, use gspot or Virtualdub and make sure that
    audio is compressed and that number of audio frames are relatively equal to number of video frames.
  • Keep the BitRate at 900bps and lower for Xvid.
  • The AVI or MP4 File should not be more than 2GB
Technically a “divx” player is a player that is able to decode mpeg-4 video streams, which includes xvid, 3ivx, nerodigital, quicktime mpeg-4
**Problems **
  1. Not all mpeg-4 features are supported by all players, like qpel, gmc so make sure your encodes dont use them.
  2. Most players support only the .avi container, which uses a fourcc system, which automatically makes every mpeg-4 stream from different mpeg-4 encoders incompatible unless the player supports all fourccs exisiting, which is not the case of course
So as all players support the divx fourcc, you can make such a player play all mpeg-4 streams (no matter what encoder used) when you change their fourcc to divx too
**Xvid Movie Playback Solution **
If you are having trouble with some xvid/divx files (usually you get no sound/picture, and the timer counter goes up erratically) try this:
  • Go to
and download the “MPEG4 Modifier”. (This program requires Microsoft .NET to be installed, shudder, but it’s worth it).
  • Open up you troublesome file in the program (this program allows you to modify some of the “meta data” (ie. not raw video/sound data) for the video). Check if the option for Pixel Size is set to “Square Pixels”
  • All of my troublesome files to date (they all were .avi files) did not have Square Pixels checked (instead it was set to a custom size). Simply checking that circle, and saving the file (as a new copy) allowed them to work flawlessly on the player.
This player is great for the family. Usually I have to always lend my parents/sibling my DVD discs, or if I’m paranoid, lend them backed up copies. Now I can simply put 6-10 movies on one Disc, which should last them for a while! :slight_smile:
**Player Freezing during Playback Solution **
Tried VCD, SVCD and DVD+R/RW discs that I had burned.
All played fine, but after a short while the player started having some of the same “freezing” problems.
After some basic troubleshooting (see below) my guess now is that my DVP642’s processor chip starts to fail when the temp get a little high.
If you check the temps on your player after heavy use, you’ll probably find the top left side of the case gets quite warm. If you pop the case open, you’ll see why it’s so warm.
There are no cooling slots or holes and all the heat generated by the power supply and processor board is contained inside the case. Is this a smart design?
The main processor chip (ESS Vibrato-II) is on the circuit board to the left side of the DVD drive. Even a long power-off, maybe 5 minutes, mine processor chip was still very warm to the touch!
I hooked the unit up with the case top off, it played perfectly for almost an hour. Found an passive heatsink laying around (from a 486SX CPU) that was about the right size of the Vibratto-II chip, and installed it.
With the player top of the case back on, and the new heatsink installed, there are no more freezes, no matter how long I play a DVDs or VCDs.
If the freezes come back, I may drill a few small cooling holes in the top over where the Vibrato-II chip is located, to let some more heat out.
**Displayin Subtitles over a semi-transparent gray background for better reading **
1- Insert a disc with a DivX or Xvid movie with subtitles file, and select the subtitles as usual.
2- Press DISC MENU button on the remote. The movie starts playing automatically
3- After the READING INDEX message, press SYSTEM MENU button twice
Doing this procedure, subtitles will be displayed over a semi-transparent gray background, making them much easier to read!!!
**For those who found the trick to enable the subtitles background useful
Here is a method to use with discs with more than one movie file **
In order to use this trick, first there is something you all must know.
When the player is set to NO MENU mode (by pressing DISC MENU button when the menu is on, or by setting it through the preferences menu `MP3/JPEG Nav’ option), it first scans the whole disc to determine all the recognizable files (movies, subtitles, pictures, mp3) and assigns them a sequential number, while a PLEASE WAIT… message is displayed on screen. This numbers are assigned to the files in the same order they appear on screen when you navigate the disc directory structure through the menu.
Once you know this, do the following steps:
1-Determine the file number assigned by the player to the AVI file and the desired subtitle file. You have to do this by navigating the
disc structure in . For example, let’s say the AVI file is number 11 and the subtitle is number 10
2-Enter NO MENU mode. After the PLEASE WAIT message disappears, the player starts playing the first file y finds. Press STOP
3-Enter the number of the subtitle file with the remote (in this example, 10) and press OK. The `little hand’ is displayed on screen.
Then press SUBTITLE button. DIVX SUBTITLE SELECTED message is displayed
4-Enter the number of the AVI file with the remote (in this example, 11) and press OK. The movie starts playing.
5-After READING INDEX message is displayed, press SYSTEM MENU button twice. After this, the player usually skips a few seconds of the movie. If this is unacceptable, just STOP and start playing again.
That’s it! It seems kind of complicated, but after doing this procedure a couple of times you’ll get used to it.
**Why not to upgrade to 1109 Firmware **
The new firmware (1109) ENABLES MACROVISION in the DVP 642 player, according to
(in portuguese). In his site, Jefferson Ryan reports his tests with both firmwares, 0531 e 1109. The conclusion is that 1109 has the infamous MacroVision, while 0531 is REALLY MacroVision free
If your player has the 1109 firmware, you can make it MacroVision free by downgrading its firmware to the 0531 version. Note that it will void the warranty, but can be useful if you really need a MacroVision free unit.
**Downgrading the Firmware from 1109 to 0531 **
Firmware 1109 has Macrovision headaches.
I accidentally found this place
http://home.ica.net/~robert/Philips
(yes, there is a ~) this place has all three firmware 0409 (my original version), 0531, and 1109 for DVP642/17. 0409 and 0531 only have two files “dvpxx.rom” and “dvpxxdv.rom”, 1109 has three files (plus dvpxxEW.rom).
Just follow the steps stated in
http://www.p4c.philips.com/files/d/dvp642_17/dvp642_17_fur_eng.pdf
burn a CD (with two files) and do installation
Many Thanks to Robert for his gr8 site
What others have to say about Roberts Site
Hi, I received my DVP642/37 manufactured on November 2004 from Amazon.com with the latest firmware (1109). As I wanted to use this player for my DivX files and Japanese DVD’s through my TV-VCR combo, latest firmware (1109) didn’t work because of macrovision. I downloaded Robert’s site files for (dvp642_17_fus_eng 0531) and after burning CD and flashing the player I must say I cannot be happier. If you guys weren’t able to flash your player, then the problem is with the writing (I used nero 6, DAO).
**LINUX, MAC, AND UNIX USERS - How to prepare your CD **
In order to get divx subtitles to work properly, you must take the following precautions
  1. If you used mkisofs to create the cd image, you cannot use the -J (joliet filenames) option.
    Although the avi files seemed to be recognized properly, subtitle files are not.
  2. Every line of text in a subtitle file must end with a carriage return and a linefeed character in typical MS-DOS fashion. Linux, unix, and mac by default use only linefeeds at the end of each line of text and thus subtitle files authored in a non-windows operating system will not be properly recognized by the player. A conversion utility such as Tofrodos, available at
Tofrodos: Convert text files to/from MSDOS/Windows/Unix (freeware),
is needed.
  1. Opendml extensions in avi files must be turned off. Recent versions of mplayer/mencoder have them turned on by default.
**Philips Oct/Nov 2004 Players have downgrade problems dont purchase it **
Philips seems to have disabled the ability to downgrade players starting with those manufactured in Oct/Nov 2004.
Those who got the Dec 2004 Manufactured 642K succeded in Downgrading
**Person 1 **
Players manufactured in Dec 2004 were able to be downgraded to 0531
Curiously, there were two box styles for sale there, a skinny white one and a fatter black/blue one.
I bought the thin white one. That’s probably TMI, but who knows.
Burned the CD using Nero Express 6.3.1.25 where the only settings
I could make was to uncheck multisession and lower the burn speed to 8x.
**Person 2 **
I’ve got a ‘slim white boxed’ DVP642/37 made in December’2004 from Target yesterday. It says “released in Jan’05” on the box, probably some Target warehouse thing. It had 1109 firm. Macrovision was ON out of the box.
  1. Downgraded to 0531 firm without any problem whatsoever, and Macrovision was GONE. I connect it through a VCR since my TV has no component inputs, so I notice the change right away! Now I can watch my “Blade Runner” which I actually bought in the store (which is a rare occasion). I did not see any significant comparative change in quality of the DIVX/XVID videos with the downgrade, and it shouldn’t be, really. As it looks and suggests, newer firmware’s decoding algorithm was probably slightly better speed-optimized, that’s all to it.
  2. Region hack ‘789-ok-0’ works, as expected. Tried some region 5 disks along with american region 1, all works. BTW PAL to NTSC conversion is not bad either.
So now this player really plays everything. I’m pretty happy with the results.
**Person 3 **
The player is Nov. 2004 model with 0531 original firmware. Brought it for my sister. Macrovision was no issue for her (She uses direct connection and it’s so easy to copy ANY DVD on your PC…), so I did upgrade and YES, noticed downgrade in my XVID movies playback quality; (increased visible pixelation). Downgraded back to 0531 and noticed no improvements and some of my newest XVIDs refused to play. Flashed back to 1109 WITHOUT ‘dvpxxEW.rom’ file in it and there is improvement!!! Didn’t test it for Macrovision, though, as I mentioned it’s no issue for us. I don’t now what to think of it, but it looks like our famous extra file does all the mess here. Hope this will be helpful for you guys.
**How To Make The Player Region Free **
For those of you who want to make the unit region-free, perform the following:
  1. Press the open/close button to open the tray
  2. On your remote, press: 7 8 9
  3. On your remote, press: OK
  4. On your remote, press: 0
Thats it now play Any Region DVD on this player
**Firmware Update Guide & Where to get the Firmware **
** Guide by Jefferson Ryan [Ryan.com.br] **
Until nov. 24 all of my tests were done with version 0531, but now version has come out - 1109. I still don’t know what has changed and even Philips hasn’t clarified it in its official document <
http://www.p4c.philips.com/files/d/dvp642k_78/dvp642k_78_fur_eng.pdf
. If you download from my Philips links, you will download the most recent firmware (The other helpful links still direct you to copies of firmware 0531). My text is still based on version 0531. I will point out what was changed (or what wasn’t changed) when I find out more. The official manual hasn’t changed.
To see what firmware version of DVP642 you have:
[Open Tray], [5], [6], [9], [ok]
If your current Model does not match your set use down arrow key on yor remote to change
Press OK to confirm.
You can change the current model number of your player to whatever versions are available (use up/down buttons on remote). Each version relates to a geographical region and a video (PAL/NTSC) system as well as other options such as the on screen display language. Press (STOP) to leave this screen withougt changing anything. If you change the version number and press (OK), then the identity (version) of your DVD player will be changed.
Note: The firmwares 0531 and 1109 for the DVP642/78 do not allow for changing the version number.
You can download the version 0531 here <
(I included links to DVP642/17 and DVP642/37 also) These links are working, but it might be necessary to turnoff any download manager to get the file.
To confirm that the archive wasn’t corrupted, or if you want to see if you have the same firmware as me, just open the archive in Winzip or in Winrar:
For the firmware 0531 of the DVP642K
For the firmware 1109 of the DVP642K (it has an extra file)
Of all these details, the most important is the CRC32. If the CRC32 of the files is the same as shown above (Philips official firmware), then you have a 99.999999977% (CRC16 has a lower precision: 99.998%) chance that it is exactly the same archive :slight_smile:
If the CRC32 is different, either you have a different firmware or it was corrupted. Don’t use corrupted firmwares, because it can totally ruin your DVD player!
[CAUTion]Updating the firmware is a dangerous process. If the process is interrupted, the player can be totally ruined. I recommend that, to be on the safe side, you plug in your dvd player to a no-break during the installation (in case of a power outage, it can happen) and verify that your CD files can be read before starting. An intelligent update first tests the new software before removing the old software, but I don’t know if the Philips update is intelligent because, at the end of the day, a process is only really intelligent if the device cannot be ruined in the processs, however Philips warns that it can. If the electricity goes out during a firmware update, for example, an inteligent device will become totally inoperable except for a special sector of the BIOS that will detect this and would ask to reinstall the firmware CD, so as to complete the process. The device would only be unusable until you loaded a “readable” CD and then the process could be completed. If the update fails, even to the point where your CD gets stuck in the drive, and to get it out you would have to open the dvd player, loosen the loader and move the emergency ejection lever below it. I haven’t personally checked this out, but it was reported here <
http://forums.divx.com/viewtopic.php?topic=59684&forum=21
by a DVP642 user that his update failed and he had to send his dvd player back to Philips.
ERASE… What?! ERASE???
One of the various things that can screw up a firmware update is scaring the user with the message ERASE that normally appears on the TV screen and in the display panel during this process. The user might believe that he was duped by somebody, and in haste he might try to abort the update by unplugging the dvdplayer from the power outlet, and as a consequence, he would completely ruin his DVD player. The old firmware in fact is first erased so that the new firmware can be uploaded, but this is just a normal part of the process.
Where to download Official Firmwares And Roberts Link
  • Official Philips Website
  • Roberts Link for 0531 Firmware
Do not upgrade to any firmware as 0531 is the Best Firmware for this player.
WARNING: Do not ‘upgrade’ player’s firmware! Newest firmware (at the moment of writing)is version 1139,
and it does NOT provide any new features, nor it will give you any extra support of xvid/divx files encoded
with Q-Pel/GMC. I couldn’t find any differences between original 0531 and new 1139 firmwares but one important
difference: the quality of divx/xvid playback.
You will see more edge pixelation and jagginess with 1139 firmware.
**Pros & Cons **
**Pros **
  • Great Audio and Video quality for DVD/SVCD/VCD/MP3-CD/Divx
  • Almost all DVD±R/RW Media supported.
  • Plays DTS on CD-R (a.k.a ‘home made’ SACD)
  • Divx , Xvid Playback.
  • Plays any VBR bitrate MP2 and MP3 audio files (tested up to 320kbps only)
  • Plays nicely VBR MPEG-1 files (aka XVCDs) without usual audio-video desynchronisation
  • Plays correct aspect ratio of SVCD files on DVD-R/RW burnt in ISO (without authoring)
  • Very nice JPEG playback support off of any media (except for DVD-RAM)
  • Region Free[not out of the box but can be made with a few key press on remote].
  • Macrovision [0531 Firmware only].
  • DTS decoder is provided.
  • Firmware Upgradable.
**Cons **
  • Doesn’t read -RAM discs.
  • Takes long to load DVD full of files.
  • Doesn’t play packet-writing formatted RW discs (tried Roxio’s, Nero’s, and Bs’)
  • Quality of MPEG-4 files (XviD/DivX) is not comparable to one you can have from your computer using proper codec adjustments and tv-out.
  • Can’t select secondary subtitles (i.e. if you have more subtitles than 1 you cant switch to second/third/ or fourth).
  • Can’t select secondary audio tracks (i.e. if you have 2 separate audio tracks, both in stereo).
  • Pathetic audio switch for VCD/SVCD (as above: doesnt work for SVCDs at all, works only for dual language VCDs - where each language is a separate mono channel of same audio track).
  • Disc Eject button missing in the Remote. Have to press STOP for a while to get the disc ejected.
  • The RW/FF buttons actually skip chapters and the Previous/Next buttons Fast Forward and Rewind.
    By this I mean that the universal icons on the buttons themselves don’t match up with the button functions.
  • Max. FF is only 8X whereas LG claims 32X in latest model
  • Time display on the player only - none on-screen. There is a place for it but it’s blank (ie --:–)
  • It can display upto 11 character long filename. So no long filename support.
    Hope you all enjoyed this Review and Research.
Do let me know about all your Positive and Negative Feedbacks on this review
Your Feedbacks will help me improve in near future
Ahaaa!! Good to see u back mate! and with such an exhaustive review.. phew.. it’ll take some time to read it all :wink:
grt review dude… :blush:
btw its available for 4.3K here in bombay… :grinning_face_with_smiling_eyes:
Hey Sanju buddy the cost is 4 month old
sorry didnt verify it in the shop again
@ Masky - hope you enjoy reading it.
Masky Suggested me to submit this to Chip
Are you sure CHIP will publish this article i have taken pains in writing it.
Guys do let me know about your views on it.
Happy Reading
woah man, this is some review now, excellent work man..
very comprehensive review !
good review m8..
well done…
plz post thumbnails of big pics in future…
it helps users on slow conn and those using low screen res :wink:
Point noted QuickFire
but the thing is that i upload images at PhotoBucket.
Just can you give me a idea of how to post images as thumbnails with photobucket
Or does imageshack only have that feature of Thumbnails.
I like to upload pics to PB as its simple and easy and all my images are organised there.
All my images are compressed to jpg and each image is hardly 10-50kb
varies with size.
I’ve had the DVP 642 for more than a yr. now, and let me tell you, its the best dvd player yet. plays everything u throw at it.
I got for a mere 60$ at that time…worth every penny.amazon.com had some special price that time, dunno whts the current price now.
And its a dream come true for every movie downloader…esp when u got a divx collection of 200+ movies :wink:
This research is going from past 4months
Just 4 Months ago i became crazy for a Divx DVD Player as i had a lot
of Divx Encoded movies and my GPU’s TV Out feature some how died dont
know. Then i thought why not get a Divx DVD Player then while i was roaming
in a mall my eyes fell on this Philips DVP642K and from that time i just started
my research and found out that one of my friends friend had this player, went to his home and tested the samples.
Well currently i am just enjoying movies on my PC but this is for all those
who are looking for a Divx DVD Player
There are also players from Mitashi available here in India but i bet hardly
people would like to get Mitashi product, have heard its gr8.
Well this is how this review & research happened.
been using it since last year december. great player.
for best pic quality use the composite cables. it simply owns. big diff from rgb.
wow, what a great review thoroughly enjoyed it.
thread rated.
repped ya for this work.
i have this player since(november 2004, i got it in gift).
i am planning to get a 5.1 home theatre system to go with it in near future. can any one suggest one i have yet to survey.
Thanks for appreciating my effort.
Your word of thanks tells me that i was useful to someone else and it feels gr8.
Well i too am looking for 5.1 Speakers which could be hooked up to this.
well..i’m not sure but i think only imageshack has tat thumbnail’ing feature…
why don u use imageshack then? its easy too…and u can organize ur pics there as well
once u register,and registration is FREE :slight_smile:
Composite - don’t you mean COMPONENT? Composite and RGB are teh same! Component = YPbPr, Luminosity,Chroma and Brightness..
Nice review,Quad.
This is the most exhaustive review on TE till date! :yahoo:
Great work, Quad!
Thread rated!
Thanks Headshot
hey Guys. what about the Mitashi DivX player? Is it any good. I read a review of the player in some magazine.It had got a good review. Does anyone have any idea about how much the Mitashi Player costs in Munbai.
lg has a new model (model 530??) which is far better than philips…
