SD card suggestion for smart home camera
I have a qubo smart 360 2k ultra camera for home purpose and want suggestions for good sd card to save video or image recordings. Online am seeing several options like class 10 and some with uhdc , I have two options available in app like SD and 2k streaming.
Dont know how much size or speed I need , looking for assistance.
a class 10 is pretty normal these days , am using a hp sd card which i got from some sale last year and it works without any problem so far but if you want the best reliability Samsung / Sandisk should be your best bet.
Sometimes the product page also recommends sd cards so do check out their page thoroughly
Can you give product link or specs please
Get high endurance microSD when it comes to 24/7 operation like CCTV (preferably SanDisk)
I wouldn’t recommend Samsung. Their sd card failed and I had sent it for RMA to Supertron on 22 Dec, I still haven’t received a replacement from them
I agree with above. Endurance card is a must for security.
Thanks this is for baby monitoring, also high endurance costs a bomb , i bought camera for 2k and sd cards are almost same price …
Yes they will be but will serve the purpose they are built for.
