Some help In Speakers
Hi guys,
One Of my friends is going to but a SONY Speaker System 2.1 with a Sub Woofer…for 4700…is that OK…actually he wants some good quality speakers which will last, so i told him Creative 4.1 is Ok i guess…but he says that he had a Bad experience with Creative.
Tell me is that OK?
He also has another Speaker System in eye, 7200, 100 Watt and the look is stunning…really sleek and small.
Can Ya tell me in 4 to 7 k what will be the best Buy?
Chaos Plz Look into it. Thanx.
Mods if there is a Thread plz Join it.
Hey scream, ur friend should go in for Altec Lansing 621 (2.1)…The output is mindblowing and clarity is good…It has around 200 Watts of RMS power…price should be around 5K…but the speakers are worth the money…Have a look at ur nearest shop.
You can visit the following website for detailss
http://www.rptechindia.com/rashib2c/productdisplayrp00.asp?productid=621&maincatgrp=&maincategory=Speakers&subcategory=Altec+Lansing+Speakers
Thanx for the option man…
But as for the Speakers, my friend is also lookinf for something small and sleek
Any Suggestions?
Are you sure MX5021 has only 90 watts RMS output…
amm how about the altec lancing atp3 2.1 spkrs which are really sleek and posibly the best 2.1 spkrs available or the altec lancing 250 they are 5.1 and are also very good…
