Sound Probs !!!
Hey Frenz… :slight_smile:
My new prob :angry: is tht when I play VCD’s or ne CD’s in my disk crive ( Samsung CD RW – I know Samsung is crap :ashamed: ) , or when I play certain games , like Fifa 2004 using ne Virtual Cd softwares , or the new demo of UEFA Champoins league my sound gets distorterd or sounds like an old tape recorder tht sounds distorted whn u switch on a mixi !!! :confused:
My speakers r fine I guess coz I connect them to my portable cd man and its as gud as its supposed to be …
So do u think its my onboard sound card trouble ( Asus A7N8X-X with raltek AC 97 ) or just case a of bad cd drive … but it happens ehn I load virtual cd of fifa 2004 too …
:huh: :huh:
PLZ HELP !!!
Tnx in advance …
Doesnt look like a CD-rom prob…
do movie’s nd music play well??
or does it happen only in games??
Hey Mare,
I guees U missed a point or 2 i posted..Thts ok…
Movies n music cd’s while playin through cd drive sounds distorted. And somtimes it happens in games… It had happened when I played Fifa 2004 by running the second cd as virtual cd…
Hop thts all… Nething else plz do ask mate !
Its nothing to do with ur cd drive nor ur speakers.
did ya try reinstalling VCD? did ya try any other VCD
Hey Matez,
So QUAD MASTER wat cud be the trouble plz tell me tht also
***uknowme007 posted 1.4 minutes later:
***Hey Hell,
Yes i tried other cd’s too…When I play mp3 from HDD the problem hasnt occured yet ! But the same songs from my cd on cd drive is distorted !
there might me a short circuit with the CD drive connection…or maybe the Lens is gone…try cleaning the lens and then check
OH…
Tht mite be one prob… Wat abt the game thing ? When I played usin a Virtual CD ?
Tnx
Well me really not having ne solution to ur problem . lets see what others have to say
Ok Master…
Thnx for the replies tho…
I have to try cleaning first up…
CHEERS !
***uknowme007 posted 4.5 minutes later:
***Hey Mtez,
Wats the best cleaner U guys wud suggest me for cleaning from DVD writer to Cd reader drives ? An All in One ?
well…try enabling DMA for ur CD writer…in Device Manager, ctrl panel…
this normally happens in PIO mode, where the processor processes the data copied from the CD to HDD, thus it’ll be slower in games…
Hey Mate,
Plz explain the steps clearly if its not too much trouble and I played it usin ( game ) virtual cd software and not the writer drive…
Vcd was played from writer drive !
Tnx
okay…u uing WinXP or 98???
here’s wht u do :
  1. on the desktop, press win key + pause/break (above page up)
  2. Gotot hardware, Device Manager.
  3. select IDE/ATA/ATAPI Controllers…
  4. Look for ur CD ROM drive in the Primary and Secondary Tabs.
  5. If the transfer mode is PIO, then change it into DMA.
thats it.
Hey Sun…
I did tht…Tnx for tht tho I am usin Win 2K…I got the steps form from another site…
But thnx mate…
Do ne of U noe wat DMA and PIO stand for ? And wats the diff…
My VCD prob seems to have been solved once I changed to DMA …Now I have to see if it re occurs in gamin usin virtual cd…
Tnx all..
U ROCK…
